tranny problems??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-25-2005, 09:07 PM   #1 (permalink)
View lil5speed's Photo Gallery
tranny problems???
its a 86 Camry, 5 speed, and when starting off in first gear, once u get the clutch let all the way out the car will start jerking, not a little jerk, but very, very hard jerks and half the time it will do this on start off, no matter how much gas u give it. and even if your coasting, say u downshift into second and coast a ways then it will start jerking at a lower rpm. usually when i shift into second from first its fine, but even then it will still jerk alittle. anyone know whats going on?? thanks
lil5speed is offline   Reply With Quote
Old 11-25-2005, 11:25 PM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
without driving the car, it sounds like the idle speed might be hunting and the motor mounts might be shot, is the idle stable?
check the big rubber intake tube for air leaks and cracks
Old 11-26-2005, 09:24 AM   #3 (permalink)
yea, the idle is very stable. when in first gear and it starts jerking, if u floor it most times it will make it go away. and it never does this jerking thing above second gear, its always first and second...dont know if that helps any
Old 11-26-2005, 01:40 PM   #4 (permalink)
V6LE_CAMRY's Avatar
View V6LE_CAMRY's Photo Gallery
hjave you changed the tranny oil?
V6LE_CAMRY is offline   Reply With Quote
Old 11-26-2005, 02:23 PM   #5 (permalink)
View Leinad's Photo Gallery
Have you checked the engine mounts ?
Or maybe the clutch is "gripping".
I'd check the engine mounts first.
Old or new car ?
Leinad is offline   Reply With Quote
Old 11-26-2005, 03:23 PM   #6 (permalink)
Gameroom cash: $304255
Sounds more like the engine is missing under load. That is usually an ignition system problem. Start with the basics. Check spark plugs, distributor cap and rotor. Also check the plugs wires for resistance with a DVM. They should be around 7000 ohms per foot of wire through the cap. I wouldn't be surprised if you found one or two of the wires had an open circuit.
Mike
Old 11-26-2005, 04:28 PM   #7 (permalink)
Ooopps! missed that one, forget what I said.
Old 11-26-2005, 06:27 PM   #8 (permalink)
it doesnt do it in reverse, so that would rule out the engine missing under load. the plugs and wires are new, i will still check them though, and replace the distributor cap. sounds like everyone is saying the mounts, so i will just replace those.
Old 11-27-2005, 09:15 AM   #9 (permalink)
Try reving the motor while being parked,or engaging in first gear with the parking brake applied. If the mounts are shot, the motor will twist abnormally.
Find a helper, easy to see when they need to be replaced.
Good luck.
Old 11-27-2005, 09:25 AM   #10 (permalink)
i'll give it a try
