Ok...I reckon i've got a bad sensor/controller somewhere, and I need opinions on which it could be.
Heres the symptoms.
RESET ECU
Start car(cold). Engine idle's at 1500-1600RPM for warmup. = Good.
Next day, engine cold. Start car, engine idles 1100-1000RPM for warmup = No good.
Every other day after that, still the same low idle at startup, until i reset ECU again.
After a reset, engine idle at cold start is normal for one start only. Thereafter, low again.
Also noticed sometimes, a low idle when warmed up. I like 700-750rpm, but it drops to 500-600 sometimes.
Ideas!??
TA!
__________________ 1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
i've always heard that with weird rpm conditions post start-up, the IAC valce is a good place to start. otherwise, hmm.... o2 sensor?
__________________ "live in the moment, forget the past and ignore the future"
Originally Posted by white3ch0c0late
Yes, Alex is the resident woman-problems guy here at TN... take his advice...
'95 i4 camry sedan -> wrecked june of 2006 by a girl who couldn't drive
'95 v6 camry coupe (dropped, rimmed, front end converted, tinted and debadged) -> current
ive heard, not sure if it works... cleaning the throttle body w/ intake/carb cleaner?
__________________ Quote-Terrastrife: Axel the confusion specialist!
-1992 Camry V6 XLE- *3VZ-FE* (with a dead auto trans.) <SOLD! Newest addition- 1987 300zx Turbo! what a blast!
No power loss. Except, the engine does have this annoying "pop" at idle. Which i posted about recently. But it sure doesn't feel like power loss...more just the low idle.
Dont remember if the 2vzfe has an "igniter" but it might be
worth checking. The pops that your getting at idle might indicate an
igniton malfunction of some kind. I haven`t studied the 2vzfe very
much, but i have an idea you might try. Your car is set to 14 degrees BTDC
right? you should check it again and at the same time rev the engine quickly
and see if the electronic spark advance is working correctly, it should never
dip below 14 degrees BTDC if it does then there may be something wrong with the
ignition.
Hm oky..so u rekn pop in another ignitior and see what she does? 2VZFE has an ignitor, and the coil is external to the distributor. Yeah i've set my BASE timing to 14-15 degrees or so. Ill check it out and see what it does. TA!
Any more ideas/explanations on the low idle problem?
Normal driving temps are perfect. It never goes over the middle, which is perfect.
A while back, i cleaned out my IAC...buut...i cleaned the bearings with thinners (doh!) and it eneded up seizing them (= kept stalling haha). I used WD40 to relubricate them..but perhaps that is what is causing it. Would that be effecting the cold start though??
