all my lights wont turn on. help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-26-2005, 08:02 PM   #1 (permalink)
View superp1noy's Photo Gallery
so like... i was changing the lights to my A/C controls because one of the lights were blown. now, for some reason EVERYTHING doesnt turn on anymore! my tachometer, speedometer, and my whole dashboard doesnt turn on! but the headlights and stuff work still. do i have a blown fuse? maybe i should have disconnected the battery in the first place... but yea... can anyone help me? if it is a blown fuse, can someone direct me to which fuse and where it is located?=/
also, will regular LEDs work instead of putting in the 74bulbs?
thanks!
superp1noy is offline   Reply With Quote
Old 11-26-2005, 09:18 PM   #2 (permalink)
by the way, my car didnt come with a manual so i have no source to look for info...
Old 11-26-2005, 10:07 PM   #3 (permalink)
Dealer Tech..not Toyota
Axel Kain's Avatar
View Axel Kain's Photo Gallery
aahhhh...sounds like a good old fuse(hopefully for you) ill check around to see if i can find info.
Quote-Terrastrife: Axel the confusion specialist!
-1992 Camry V6 XLE- *3VZ-FE* (with a dead auto trans.) <SOLD!
Newest addition- 1987 300zx Turbo! what a blast!
Axel Kain is offline   Reply With Quote
Old 11-26-2005, 10:12 PM   #4 (permalink)
Dave's
Gameroom cash: $122050
View Dave's's Photo Gallery
Let people know what you've got (year, etc.)- it might help. These guys do a pretty good job of coming up with the answers. Might start below and to the left of the steering wheel. Most have a little bin there that pops out to allow access to some of the fuses.
Dave's is offline   Reply With Quote
Old 11-26-2005, 10:20 PM   #5 (permalink)
Axel Kain's Avatar
when popping out, there are 2 tabs one on each side, push those toward eachother, and it slips out....if this is a gen 3, (92-96 i think) and i believe that has some fuse locations on it. it will most likely be labeled, cluster, dash or console lighting/ illumination.
Old 11-26-2005, 10:32 PM   #6 (permalink)
LMAO someone kick me.... please... it was the dimmer knob for the past 3 hours....
but thanks LOTS for your attempts to help me...
reminds me of my cousin who always thinks something is broken... until i tell him to raise the volume.... hahahahha
Old 11-26-2005, 10:44 PM   #7 (permalink)
Axel Kain's Avatar
LOL!!!!!! its cool man, glad we could kinda almost help....
BTW, are you gonna stay with this site, its a great sorce of info for any little prob.
Old 11-26-2005, 11:12 PM   #8 (permalink)
hehe yeppp im probably going to be an active member on this site. im pretty much starting fresh with this whole car thing... i just got my first car (1999 camry i4) and at first i was like... nahhh i wont fix it up... but then i came accross this site and i saw what cool stuff you guys did to your cars and that got me hooked. everything i had gotten into in the past, i would always fix them up and make them better. 1/64th scale R/C cars to 1/24th scale R/C cars. then came the computer, then Airsoft, and man... who would've known that a friggen car would be next? hahaha. well once i expand my knowledge about cars and what not... expect to see more of me around the forums
Old 11-26-2005, 11:31 PM   #9 (permalink)
1993 Camry XLE
HoboJoe's Avatar
View HoboJoe's Photo Gallery
Alright, hope to see you around on the forums.
-Will
HoboJoe is offline   Reply With Quote
Old 11-29-2005, 05:14 PM   #10 (permalink)
OMG ok this happened again... and now im SURE that it is a fuse. It is a GEN 4 1999 camry i4. can anyone tell me Where the fuse is?! =/
Old 11-29-2005, 05:23 PM   #11 (permalink)
0111010010
SnakeyeS's Avatar
View SnakeyeS's Photo Gallery
7.5 amp fuse, red/maroon in color located behind coin box left of steering wheel. Just pull the coin tray out, disconnect ur negative battery cable, and use a needle nose pliers to remove it.
"Knowing is half the battle."
Color Valentine One Displays
SnakeyeS is offline   Reply With Quote
Old 11-29-2005, 05:24 PM   #12 (permalink)
thank you! ill repost if i have any problems =]
*edit* done and replaced. THANK YOU!
Old 11-29-2005, 08:02 PM   #13 (permalink)
1B2 V6 Clean!
Camon19z's Avatar
View Camon19z's Photo Gallery
definetley is a fuse same thing happened too me
Camon19z is offline   Reply With Quote
Old 11-29-2005, 08:46 PM   #14 (permalink)
Iron Chef IV
View drunken_panda's Photo Gallery
It could be the dimmer switch. I know that on the Previa it can burn out. Instead of getting a new one (who really dims their lights?) you can jump the reostat.
drunken_panda is offline   Reply With Quote
