Odd Problem, need your advise
Well, I replaced the stock struts in my 94 V6 with the Tokico FULL strut replacements. I also replaced the front strut caps and boots as well as the lower spring insulators. Ok, the ride is awesome! Here is the problem, on the front, passenger side, every time I turn left or right, it makes a sound like the spring is slipping on the rubber mount on top! Hard to describe, but it is like this... turn the wheel to the right, and I hear... bump, bump, bump.. as the spring gets bound kinda and then releases.. and the same way to the right. I have checked the spring lock on the bottom and it has not moved. The spring fit correctly. You can barely hear it outside the car, but inside, you can hear it better as it is sounding thru the mount under the hood to the car body more. I had the car aligned and tires rotated and balanced as well, no help. I am at a loss. The strut cap is stationary and the strut cartrage moves with the tire, twisting the spring. The strut shaft remains stationary as it is bolted to the strut cap as well. So, it HAS to be the spring moving on the rubber on the strut cap, that is my only end result. Any help on this is appreciated!
SCDTRD
1994 Toyota Camry V6 XLE  I LOVE it!
And the journey continues........
