Runs like sh!zz!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-29-2005, 02:14 PM   #1 (permalink)
Gearhead User
drducttape's Avatar
View drducttape's Photo Gallery
Runs like sh!zz!!!
Hey,
Here's the rundown so you can tell me what I screwed up:
Replaced crankshaft (had a knock)
put everything back together again.
No more knock, runs smooth when warm but runs like shiz!!
Gutless, completely!
Throwing a code 52, knock sensor signal. Sensors have 0 continuity and need to be replaced.
Can the code 52 cause the engine to be completely gutless, or did I screw up on the timing belt, or what??
Thanx for your input.
Terry.
drducttape is offline   Reply With Quote
Old 11-29-2005, 02:55 PM   #2 (permalink)
The 6"4 Viking
Zandro's Avatar
View Zandro's Photo Gallery
Do you have a manual that you used when you aligned the tming belt?
or did you just put it back the way you think it was?
Zandro is offline   Reply With Quote
Old 11-29-2005, 03:03 PM   #3 (permalink)
Gearhead User
drducttape's Avatar
I followed the instructions, did it a month ago, but I'm pretty sure that I needed to have the crank @ TDC and the alignment marks on the cam gears to the top.
Probably should mention the car is a 92 Camry 3vzfe v6.
Old 11-29-2005, 05:17 PM   #4 (permalink)
rusty9's Avatar
Gameroom cash: $441505
View rusty9's Photo Gallery
probably off a tooth on timing. check all your marks again after you change the knock sensors.
rusty9 is online now   Reply With Quote
Old 11-29-2005, 05:36 PM   #5 (permalink)
Gearhead User
drducttape's Avatar
Hah!!!
Got it!!!
Got a brainwave after I posted the last time.
I took my timing light and hooked it up to #1 let the car warm up, then shot the timing marks on the crank pulley to make sure it was @ tdc, and it was, after it warmed up.
I then shot the cam pulleys, and they were (Bang on rusty9!) exactly one tooth off.
A little screwing around later, and pow! I can smoke my tires!
Here's a golden nugget in case someone searches this thread later:
http://www.yotarepair.com/Timingbeltinstructions.html
That is timing belt alignment instructions for alot of Toyota engines.
Thanks!!
Terry.
Old 11-29-2005, 07:21 PM   #6 (permalink)
rusty9's Avatar
yeah sometimes they spring back when you put tension on them. they sell a cam lock tool but ive found a nicely sized 2x4 does the trick too.
Old 11-29-2005, 07:38 PM   #7 (permalink)
Lex Zues!
RedPhoenix's Avatar
iTrader Score: 12 reviews
View RedPhoenix's Photo Gallery
congrats, problem solved
Sold ^
Originally Posted by dysk8forlife
supercharger whine>girlfriend whine
RedPhoenix is offline   Reply With Quote
Old 11-29-2005, 08:42 PM   #8 (permalink)
Gearhead User
drducttape's Avatar
Yeah, it would have been a real simple job, except for that....
Pulled the tensioner pulley off and was about to bring the belt over one notch and I heard that sound (zzzzzzzzzzik!), and I knew what happened... Valve spring tension had spun my exh cam over. So instead of just shifting it over one notch and calling it good, I had to start from scratch timing the thing..
So I redo the whole thing, and jumped in the car to start it up, and it turned over twice and sounded real funny... I was like, what now!! So I inspect it closer, and the stupid exhaust cam is off 90DEG. It must have sprung again when I had gone for a tool run!
So I did it again again, and paid a little closer attention, and got er done right.
Could have been so simple!
Terry.
Old 11-29-2005, 09:17 PM   #9 (permalink)
engineer in training
Gameroom cash: $145055
Good job! I remember the first time I encountered the damned hydrolic tensioner, I dont have anything to compress it back with and it drove me crazy trying to get that bugger back in right.
Old 11-29-2005, 09:24 PM   #10 (permalink)
Nad1370's Avatar
View Nad1370's Photo Gallery
^^ You can just run the 12mm bolts that hold it very slowly and evenly.
Although getting it compressed in a vise and pin it up is sweet.
Nad1370 is offline   Reply With Quote
