Originally Posted by cheezthis
Thermostat? Usually when a tstat goes bad, it's stuck open, and in turn overcools. However, I don't think that's the case here. The engine coolant temp is normal. It's the heater that's not.
I agree though, if pulled, replace anyway.
As your thermostat ages, the spring that opens it up gets weaker and weaker from all the heating and cooling cycles it has gone through. As a result, it opens up sooner and therefore doesn't let the engine get as hot as it should before allowing the coolant to be released from the block and be cooled by the radiator. The result is you don't get as much heat since the coolant isn't as hot as it should be. This will also effect gas mileage just a bit too. If the engine runs a bit cooler (or takes longer to really reach full operating temperature) your fuel/air mixture will be a bit richer during these periods, resulting in a slight waste of some fuel.
Do what has been suggested as a first step. Change your thermostat. It's cheap and easy. Also change the gasket with the thermostat. I just did this about 10 days ago on my 94 with only 75,000 miles. The car now warms up a bit faster and the heat is noticeably hotter. I would recommend a Toyota OEM thermostat and gasket.
If that doesn't do it, then look for other things, like problems with the heater control valve under the dash, a clogged heater core or the slide bar controls under the dash not opening or closing fully.
Mike
