Found Leak 1 of 2 - Timing Belt? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-01-2005, 01:43 PM   #1 (permalink)
Lex Zues!
RedPhoenix's Avatar
iTrader Score: 12 reviews
View RedPhoenix's Photo Gallery
3rd Generation Found Leak 1 of 2 - Timing Belt?
Its leaking oil like a seal is gone or something. Is there a gasket here? How hard is it to replace, I dont have my Haynes handy right now.
Sold ^
Originally Posted by dysk8forlife
supercharger whine>girlfriend whine
RedPhoenix is offline   Reply With Quote
Old 12-01-2005, 04:16 PM   #2 (permalink)
Lex Zues!
RedPhoenix's Avatar
bump
Sold ^
Old 12-01-2005, 04:29 PM   #3 (permalink)
View A2brb's Photo Gallery
It's either the Crank shaft seal or the Camshaft Seal.
You will have to take the crank pulley off to get to the seal.
Same with the Camshaft Seal..Take the Cam Sprocket off.
If you don't have a hanes manual handy, go spend the $20 and buy one. It would take me too long to explain how to do it. It's just like doing the timing belt. You might as well replace the timing belt while you have it off.
I just replaced both of mine 3 weeks ago.
Let me know if you need help..
-Ben
92' 2.2L 16V Camry
91' Gti VR6-t
"If you aim at nothing, you will hit it every time" Zig Ziglar-
A2brb is offline   Reply With Quote
Old 12-01-2005, 04:35 PM   #4 (permalink)
Moving Forward
View Cyorke's Photo Gallery
could also be the oil pump seal. If you know how to do the timing belt pull it down like you are going to do that and take a look at it. Like A2brb said get the haynes manual if you dont have one or the repair manual that is stickied at the top of the forum.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 12-01-2005, 07:13 PM   #5 (permalink)
View barthmonster's Photo Gallery
My '94 2.2L had the same thing. It was the Oil Pump seal and I replaced it fairly easily while doing the timing belt. Needed a new Oil-Pump O-Ring and the Oil Pump Seal.
Good Luck.
barthmonster is offline   Reply With Quote
Old 12-01-2005, 08:57 PM   #6 (permalink)
View Leinad's Photo Gallery
The timing belt won't last long under these conditions.
Depending on the leakage.
Good luck.
Leinad is offline   Reply With Quote
Old 12-02-2005, 05:00 AM   #7 (permalink)
Lex Zues!
RedPhoenix's Avatar
well the leak is SO minor. like once a weak it will leave a few drops. but i have a toyota guy, hes going to look at it when i do my t-belt.
Sold ^
