Need help with spark plug diagnosis - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-01-2005, 02:43 PM   #1 (permalink)
View alkon's Photo Gallery
2nd Generation Need help with spark plug diagnosis
I have a 91 Camry LE with 180k miles. Recently, it has been running as if it lacks complete power. This morning I began to look at variious aspects of the engine to determine the problem. When I pulled the spark plugs, I notices that all of them had good appearance (light gray in the firing area) except for one. My #2 plug has a medium brown coating on the electrode and ceramic area surrounding the firing tip. It is not oil fouling. I am running Bosch Platinum plugs.
What would cause this?? Would this appearance of the plug idicate that the plug does not fire at all... or, is it firing inefficiently. I changed the plug wires about 8 months ago with Toyota OEM wires, therefore, I can't imagine there is a problem there. Additionally, I conducted a compression test and got 170 - 175# on all six cylinders... including #2.
alkon is offline   Reply With Quote
Old 12-01-2005, 04:07 PM   #2 (permalink)
View Gary_602Z's Photo Gallery
I know a lot of people don't like Bosch plugs. I am not sure if that is your problem or not but it would be an easy try. Did you replace the plugs when you did the plug wires? Pesonally I would say the plug is firing okay. If it was a bad missfire on that cylinder it should be more black.
Let us know what you find out.
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 12-01-2005, 07:18 PM   #3 (permalink)
View barthmonster's Photo Gallery
I recently went to NGK Irridium Plugs and at the same time replaced my old, cracked Accel Plug wires (I have no use for Toyota OEM wires) that were 8 years old with NGK wires from www.importcarparts.com. The change of both of these items on my '94 with 233k made a world of difference!! Runs great!!
barthmonster is offline   Reply With Quote
Old 12-01-2005, 08:13 PM   #4 (permalink)
Nad1370's Avatar
View Nad1370's Photo Gallery
Sorry but you have to get NGK's in there before everything. Bosch platinums suck on toyota engines.
Change it and see if it changes.
Nad1370 is offline   Reply With Quote
