Where is the plug to fill transmission fluid. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-02-2005, 10:58 PM   #1 (permalink)
ApexiCamry
View DiscoPotato's Photo Gallery
2nd Generation Where is the plug to fill transmission fluid.
I have a 1989 toyota camry 4 cyl 5 spd. I don't know where the whole is to put the transmission fluid. I only know where the drain plug is. Need to know asap.
DiscoPotato is offline   Reply With Quote
Old 12-02-2005, 11:40 PM   #2 (permalink)
The Greek....
GrkBallaG's Avatar
iTrader Score: 13 reviews
View GrkBallaG's Photo Gallery
to fill the trans up with fluid you take the dipstick out, put a funnel in place of the dipstick and pour away....
The SLAMry.....
Slammed, Carboned, 5sp Swapped, Big Braked, RMM Lipped And Ready To Be Daily Driven!
Originally Posted by UfoZ View Post
Tits! Best non turbo Camry there is.
GrkBallaG is offline   Reply With Quote
Old 12-02-2005, 11:45 PM   #3 (permalink)
ApexiCamry
awesome! thanks man
Old 12-03-2005, 12:19 AM   #4 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Does the 5sp even have a dip stick tube? My Celica does not and you fill it by pouring oil in a hose piped into the hole on the side. Eiterh that or use a pump.
But I believe that a manual transmission uses gear oil not transmission fluid.
2007 Camry 2.4L 5M
Old 12-03-2005, 12:33 AM   #5 (permalink)
tC
View 95camguy's Photo Gallery
since its the manual there is a fill bolt on the side of the trans.(like touringcamry said u need a hose or tube to fill the manual). also, may i suggest u go with redline mt-90. it buttah smooth. kinda pricey though.
my $.02
07 tC MT
-TRD RSB
-TRD Quick Shift Kit
-TRD Exhaust
95camguy is offline   Reply With Quote
Old 12-03-2005, 12:48 AM   #6 (permalink)
The fill plug is 17mm bolt IIRC. 3/8" ID hose is perfect fit into that hole. Get about 5 ft clear vinyl or PVC hose from the hardware store. Most hardware stores sell it by the foot.
2007 Camry 2.4L 5M
Old 12-03-2005, 03:35 AM   #7 (permalink)
ApexiCamry
ohh i see. thanks for the info guys.
