Originally Posted by Phi
Great job man
But I'm alittle confused. Why did you get 180 degree U-bend pipe if you only need 5" of a straight piece :-? You didn't relocate the filter down to the bottom of the car correct?
Well, I got the 180 degree U-bend because at first I intended to make it cold air after seeing 88LE's intake. Then, after I ordered the pipe I found out that I didn't really know what to do about the crankcase hose and the other, so I got kind of demoralized and gave up for a while (approx 8 months or so, heh). So yeah, I still intend to make it cold air, I just wanted to replace the intake tube.
Originally Posted by Zeek321
nice man, hey about how much did u spend?
Not too sure on that. I think maybe 50 bucks total for just the materials?
Originally Posted by Luc
Although it looks pretty nice, but may I ask what's the point of replacing it? Was the OEM leaking?
Luc
Nah, I just wasn't satisfied with the way the stock intake tube looked. Also, it was kind of sagging because of the weight of the air-flow meter and the filter, so that kinda made me want to change the intake tube.
