hydrogen sulfide "rotten egg" odor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-04-2002, 04:09 PM   #1 (permalink)
View Lokamaya's Photo Gallery
'98 LE, 4cyl, 38K miles
I bought the car used, and have had intermittent hydrogen sulfide odor from the exhaust sine I have been driving it. Performance and mileage are good. I now have new platinum plugs which were installed by a shop in a failed attempt/ripoff to solve the problem. It is still in emissions warranty, I have since learned.
The Toyota shop sent it right back and said the problem is 87 octane gas, and that it is common in Toyotas. I should burn higher octane. They did no checking at all. They said to bring it back if changing gas doesn't help. I have researched and found that sulfur content of gas, which is not tied to octane, could play a part. I have also learned that the gas in this area at this time has 85ppm sulfur, which is pretty low. Changing gas has not helped, but I have purged a lot of the odor out by accelerating up hills.
I want to have this remedied under the emissions warranty, and am looking for advice on what to ask them to do or look for. I think it may be the O2 sensor and over-fueling. If all engine checks are in spec, should I press them to install a new converter?
Is Toyota supplying the exact same converter, from the same vendor, or a better one than the original?
Is this really a common problem on Toyotas?
If I get no satisfaction from Toyota, would an aftermarket converter such as Catco brand be more likely to solve the problem than the Toyota one?
Is this likely a faulty converter or engine or fueling maladjustment. A chemist at the Citgo refinery said that blaming in on the gas is just a lie, but I can't figure out why the dealership would blame the gas when they had an opportunity to do warranty work and send in a claim for payment.
Any experience or advice would be appreciated.
Lokamaya is offline   Reply With Quote
Old 12-04-2002, 04:23 PM   #2 (permalink)
Ha Ha! Noses on dowels!
baartman's Avatar
View baartman's Photo Gallery
throw in a bottle of fuel injector cleaner. cant hurt rite?
My car:
1988 Mazda 323 GTX. 4WD/Turbo
I miss my 86.
baartman is offline   Reply With Quote
Old 12-05-2002, 03:50 AM   #3 (permalink)
View Ken4's Photo Gallery
Change your ATF.
Ken4 is offline   Reply With Quote
Old 12-05-2002, 05:54 AM   #4 (permalink)
View crazy_camry's Photo Gallery
isn't that smell what clutch fluid smells like, maybe its leaking? or the cat is on the blink, and letting bad smells through. im no expert though, just a thought
crazy_camry is offline   Reply With Quote
