Originally Posted by TRDragoon
theres 2 wires connected to the power source.
one wire for "always on" (direct to your batt) this one keeps your memory for your station, clock, setting etc.
2nd for illumination, this one is turned on when the ignition key is on....
check the illumination one...
but take it back to the shop....cuz you can either do major damage to the radio (happened once with me) or burn a fuse
hmmm....for this one, i'd disagree with you......
you should try little things like this yourself, else you'll never learn...and burning fuses is one of the things that will help you learn....just go buy some new ones....
and hey....if it's actually something wrong with the radio, then get a new headunit.....remember...when something breaks, it's a good time ot upgrade...
