Coolant question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-19-2005, 07:21 PM   #1 (permalink)
2001 Camry LE
View Nuke209's Photo Gallery
Coolant question
been filling up my coolant every 2-3 weeks [the reservoir]
is that normal or do i have a leak
cam gen 4.5
Nuke209 is offline   Reply With Quote
Old 12-19-2005, 07:28 PM   #2 (permalink)
Still confused...
95WhiteCamry's Avatar
iTrader Score: 7 reviews
View 95WhiteCamry's Photo Gallery
sounds like a leak to me
"live in the moment, forget the past and ignore the future"
Originally Posted by white3ch0c0late
Yes, Alex is the resident woman-problems guy here at TN... take his advice...
'95 i4 camry sedan -> wrecked june of 2006 by a girl who couldn't drive
'95 v6 camry coupe (dropped, rimmed, front end converted, tinted and debadged) -> current
95WhiteCamry is offline   Reply With Quote
Old 12-19-2005, 08:43 PM   #3 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
do you see a puddle under your car?? coolant in your oil when you change it?? if no to both, then no leak.
the reserve take is only for when the fluid expands and contracts due to pressure and temp, its OK if it is a little low... the real problem will be when your temp gauge goes up higher than normal.
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 12-19-2005, 09:49 PM   #4 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
if you fill it up every 2 weeks, then there is a leak.
it might not be a bad leak but as zoni said, check and see if there is a puddle.
or just run the car for 15 min and leave it on for 5min on the parking lot. if you see a puddle or some drips, then you might want to look into it.
my friend's solara leaked but as the water dripped, the engine's heat vaporized everything
skewe is offline   Reply With Quote
Old 12-19-2005, 10:02 PM   #5 (permalink)
View Gary_602Z's Photo Gallery
All leaks do not have to leave a puddle! If you are only going through that much it could be just a seep some place that is running onto something warm and evaporating. Look everything over with a fine tooth comb and pay real close attention to any damp spots under hoses or fittings.
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 12-19-2005, 10:23 PM   #6 (permalink)
I'm a Mac
zoni's Avatar
ok fine, all leaks done have a puddle, but you will see something... and with coolant you will SMELL something.
Dave Zoni
Old 12-20-2005, 01:19 AM   #7 (permalink)
Dave's
Gameroom cash: $122050
View Dave's's Photo Gallery
Unless it's going out your exhaust and you're looking at the engine.
Dave's is offline   Reply With Quote
Old 12-20-2005, 01:03 PM   #8 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Rinse down the engine bay with water (if it is warm out)
open the hood after a drive that takes the cooling system up to pressure ( hot engine) and lean in and sniff for coolant.
Don't open the rad cap yet.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 12-21-2005, 04:00 AM   #9 (permalink)
I'm a Mac
zoni's Avatar
and what would cause that???
Dave Zoni
Old 12-21-2005, 04:15 AM   #10 (permalink)
Dave's
^ Head gasket leak between water jacket and cylinder. May see white smoke from exhaust. But that depends somewhat on the amount leaking. And not all white smoke is a bad head gasket. (It's typical to see some as the engine is warming up, etc.)
Old 12-21-2005, 07:36 AM   #11 (permalink)
Darkside Cut Me!!!
Head Gasket leaks... look at your spark plugs, and see if any are cleaner than the others.
Also... how does the oil look?
2004 RX330 Sport
2003 Cam I4 XLE
Old 12-21-2005, 10:31 AM   #12 (permalink)
I'm a Mac
zoni's Avatar
true, but in the case of a HG leak, its normally not just that. possible, but not likely. especially on such a new car, in stock condition.
Dave Zoni
