suspension squeaking (over bumps) and sounds when turning - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-21-2005, 05:19 PM   #1 (permalink)
View AyzhenInvasion's Photo Gallery
4th Generation suspension squeaking (over bumps) and sounds when turning
ok so my suspension squeaks when i go over bumps?
also when i turn my stearing wheel, it makes this weird noise like it doesn't wanna turn or something, its really hard to describe... itsl ike, when ur joints don't wanna move, but u bend it, it makes this like weird noise... get what i mean...?
thanks for ur help
AyzhenInvasion is offline   Reply With Quote
Old 12-21-2005, 05:23 PM   #2 (permalink)
View keithy's Photo Gallery
Might be your stabilizer bar bushing. If it is squeaking, try apply some marine grade white lithium grease on the bushings. I fixed mine that way, as suggested by some of my senior TN members.
also when i turn my stearing wheel, it makes this weird noise like it doesn't wanna turn or something, its really hard to describe... itsl ike, when ur joints don't wanna move, but u bend it, it makes this like weird noise... get what i mean...? thanks for ur help
Not enough info to tell, but my guess on this would be your cv joint.
keithy is offline   Reply With Quote
Old 12-22-2005, 12:08 PM   #3 (permalink)
View bassthrive's Photo Gallery
I had a creaking noise during low-speed turns like maneuvering into and out of a parking spot or garage. Removed the strut assemblies, repacked the front upper mounts with grease and all is quiet. Had a squeaking upon bumps from my rear passenger wheel. Couldnt pinpoint it so I hosed the spring and whatever else I could see on the upper mount with lube. No more squeak. Stabilizer bars are also worth lubing while you're at it.
now with 100% more clickability
bassthrive is offline   Reply With Quote
Old 12-22-2005, 12:51 PM   #4 (permalink)
Godiva Gifts
97Heaven's Avatar
View 97Heaven's Photo Gallery
About the turning your steering wheel problem, check both sides of the car to hear where the sound is coming from. It might be a ball joint in need of replacement.
4TH GEN CAMRY | 4TH GEN ACCORD
97Heaven is offline   Reply With Quote
Old 12-22-2005, 05:21 PM   #5 (permalink)
ok will chek, thnx guys
Old 12-22-2005, 10:48 PM   #6 (permalink)
View elhsgrad04's Photo Gallery
my rear wheel does this too, do you have to drop the strut back out to do this?
elhsgrad04 is offline   Reply With Quote
Old 12-23-2005, 12:42 AM   #7 (permalink)
97camryman's Avatar
View 97camryman's Photo Gallery
Mine does exactly what you say also. Its only when cold out though, at slow speeds everything squeaks and makes a groaning noise like my knees do if I am really quiet. I just ignore it and turn up the radio. It goes away any time its warm out so I dont mind it. I have been running tein s-tech springs with tokico struts for awhile now.
Home Page: http://www.cardomain.com/memberpage/506928/1
5S-FE Turbocharged @8psi with 5-speed auto to manual swap
97camryman is offline   Reply With Quote
Old 12-23-2005, 10:23 AM   #8 (permalink)
95% Biker / 5% Driver
Digger1's Avatar
View Digger1's Photo Gallery
4th Generation
For the steering problem - be sure and check the tension of the power steering belt. It will squeal if it is too loose.
Digger1
"If you don't understand the technology you depend upon, you will someday be a victim of that technology."
Digger1 is offline   Reply With Quote
Old 12-23-2005, 02:48 PM   #9 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
thanks for ur help
for the suspension, welcome to the defective strut mount for gen 4
http://toyotanation.com/forum/t112562.html
there are maybe 30-50 threads about it but no resolution except to change it. Change it to the new part cos if not, it will still squeak
skewe is offline   Reply With Quote
