If you hear clicks while accellerating around a corner, its most likely your CV joint. Get it replaced as soon as you can. It should cost about $200 or less total at a shop. The labor isn't too much.
A CV joint is a more advanced universal (U) joint. Instead of the velocity changing as the shaft spins (what happens with a bent U joint) the velocity stays constant. Look it up on howstuffworks.com. I think they have an article on it there.
-Charlie
