Disc Brake Upgrade - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-08-2002, 07:09 PM   #1 (permalink)
View monkiex's Photo Gallery
Disc Brake Upgrade
Trying to put together a groupbuy for Solara Front disc brake upgrade. The kit would include everything you need to install it. You would
get rotors, calipers, mounting brackets, pads, stainless steel hoses, all
the fittings, and instructions. There are a few different brands of rotors
that we use, depending on wheel size. We use Wilwood calipers, there are
various pad compounds to choose from, but it typically comes with Wilwood Polymatrix 'D' pads (their street compound), or Hawk HPS pads (high performance street). We make custom brackets for the kits, and include Goodridge stainless steel hoses. If we can get 20 or more the kits would be like 20% off. If interested please email me at josephsantos@comcast.net
Thekits would be coming from precicion brakes company. This is a great deal if you ever considered the brembo big brake conversion kit that is going for about $1800+. Email me for pricing and more info or any questions. I would like to see this group buy happen. Thanks!
monkiex is offline   Reply With Quote
Old 12-08-2002, 07:10 PM   #2 (permalink)
13” x 1.25” DBA Longlife Gold curved vane, cross drilled and slotted rotor re-drilled to suit your application
Wilwood Superlite IIA 4 piston caliper
Wilwood Polymatrix "D" pads
Steel caliper mounting brackets SS braided Teflon flex hoses
Grade 8 hardware
Options:
DBA Longlife Slotted only rotor
Thermlock pistons and heat shielding
Autocross pads, Wilwood Polymatrix "B"
Race pads, Wilwood Polymatrix "C"
Powder coat calipers (most colors)
can be customized to fit most applications
