'99 5S-FE Knock, I've Tried Many Things - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-31-2005, 11:21 AM   #1 (permalink)
95% Biker / 5% Driver
Digger1's Avatar
View Digger1's Photo Gallery
4th Generation '99 5S-FE Knock, I've Tried Many Things
Hello all,
Please check my signature block for specifics on my Camry.
The problem started suddenly when the car had 62K miles on it. It had been sitting in the garage for a week when my wife tried to start it. She said it would not start for a while, it would just crank. When it finally started, she said it backfired pretty bad and the engine started making a loud knocking noise as it idled. She shut it down immediately. I suspect she was depressing the accelerator pedal when she was trying to start it. Even though she has not driven a car with a carburetor for many years, she still seems to have a hard time keeping her right foot on the floor when starting a car with fuel injection. Makes me crazy!
Anyway, I started the car up that evening and noticed a knocking noise that had never been there before. Since I had checked the valve clearances just a few thousand miles before this event, I pulled off the valve cover and looked everything over.....everything was fine.
The next thing I tried was a few bottles of Techron. No help.
The next thing I tried was a check of the EGR valve. Everything checked out fine.
I next tried to steth the engine. I don't have a real good mechanic's ear, but the noise definitely seemed to be coming from the top end. I stethed the oil pan and the lower part of the engine block and couldn't hear the knock much at all at these places.
The next thing I did was to buy a new knock sensor (mucho $$) and put that in. No help.
The next thing I did was to take it into a Toyota dealer. They did some load tests by pulling spark plug caps off one-by-one and said it did not seem to be a rod knock. They then ran some top end cleaner through it. Cost me $100 and did not help.
I then sucked lots of Sea Foam thru the engine via the brake booster hose. I even stuffed a Sea Foam soaked rope into a few of the cylinders and let it set there for a few days to dissolve any deposits. No help.
The next thing I tried was to pull off the exhaust manifold, check it out for cracks and such, and reinstall it using a new gasket. No help.
The next thing I tried was a tank of premium gas. No help.
The next thing I tried was a new timing belt and new pulleys. No help.
The next thing I tried was to send out this post and plea for help.
I'm bummin'. You can hear the noise when you start the car. It is a metallic sounding knock, sounds like it is somewhere in the top end. My Dad is a pretty experienced mechanic and says it sounds like piston slap. I can't imagine that this is what it could be. Remember, the engine started making this noise suddenly, after the big backfire (see above). The noise can be heard from the street as my wife drives the car away. I've noticed that when I'm driving it, the noise seems to go away above 3000 RPM and is most pronounced at low RPMs, especially during acceleration and going up hills. It gets a little quieter when the engine is warm, but not much.
I've changed the oil religiously every 3000 miles in this car. When I pull off the valve cover, it is very clean with no hint of sludge.
I'm at wit's end. I'm thinking seriously of throwing my hand up in disgust, purchasing towing insurance, and runnin' 'er till she blows!
Any assistance would be greatly appreciated.
Digger1
"If you don't understand the technology you depend upon, you will someday be a victim of that technology."
Digger1 is offline   Reply With Quote
Old 12-31-2005, 11:38 AM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
You can pull the sparkplugs out and shine a light into the holes to look at the piston tops, see if there are any shiny spots. If so pull the timing belt covers and see if the marks are still in alignment. While putting a belt on a 98 Camry I discovered turning the crankshaft backwards will allow the timing belt tensioner to loosen just enough to slip a cog or 2. The 5SFE isn't supposed to be an interferance engine however built up carbon could touch the valves. It's possible the backfire made the crank jump backwards.
My mom has the same problem with hitting the gas on f/i vehicles. She's even called me at work to come fix her car. Once I get there I tell her to show me what it's doing. Then have to remind her yet again to take her foot off the accellerator. But hey, it's mom, what am I gonna do, yell at her? Can't see that happening. heh
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 12-31-2005, 02:47 PM   #3 (permalink)
Moving Forward
View Cyorke's Photo Gallery
You didnt mention the water pump being replaced. Sometimes when the bearings go out in it you will hear a knocking noise coming from it. FI you ahve a steth you can get to it right under the alternator. there is a water neck and it is in the same location as the pump. You may try listening to it. IF you replaced the t-belt and all the pulleys and suche it would be a pain if it was the pump since you awill ahve to remove the belt to get to it. COuld be psiton slap also. If you are pulling plug wires it may change the sound if it happens to be piston slap. IT would seem odd for it to be this though if it was fine before it was parked for the week.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 01-01-2006, 11:04 AM   #4 (permalink)
Digger1's Avatar
Tercel,
Thanks for the input. I'll pull the plugs and give the piston tops a look. I did just replace the timing belt. The valve timing was good when I started the job and good when I slapped the timing belt covers back on 'er.
Cyorke,
Yeah, I've thought of the water pump. I'll steth that area.
However, when I had the timing belt off of it, I grabbed the water pump pulley and tried to move it in all directions. It seemed solid.
Thanks for the inputs.....are there any more ideas out there?
Digger1
Old 01-08-2006, 09:05 AM   #5 (permalink)
Digger1's Avatar
Dudes,
I stethed the waterpump area and I did not hear anything that seemed to indicate that the knock was coming from that area.
Regardless, the next time I change coolant in this car (about 10K miles from now), I think I'll throw a new waterpump on 'er and see if that clears up the noise.
Digger1
Old 01-08-2006, 05:05 PM   #6 (permalink)
Moving Forward
Originally Posted by Digger1
Dudes,
You know this involves replacing the timing belt also. It is not like a SBC taht you jsut take the fan off the front and there you have a water pump. Just want to make sure you are aware so you arent surprised when you ahve to disassemble everything under the timing cover to get to it.
Chris
Old 01-09-2006, 09:49 AM   #7 (permalink)
Digger1's Avatar
Thanks, Chris,
As you can see from my first post in this thread, BTDT.
As a matter of fact, I've got less than 1000 miles on the new timing belt.
Since I've done the job so recently and I took good notes, getting in there to replace the waterpump SHOULD be a breeze (KOW)!
Digger1
Old 02-06-2006, 11:05 PM   #8 (permalink)
Digger1's Avatar
Angry Grrrr! New Waterpump - Still Knocks
I put a new waterpump (OEM) in and the noise is still there. (Plz see my post at the top of this thread.)
I just got back from a trip to Minnesota and noticed that it knocks really loud when the engine is really cold. She goes down the road good, though, I got over 34 mpg on the trip.
I'm considering getting an oil analysis done....know of any good labs? Will such an analysis tell me if the engine is beating itself to death? BTW, the engine is burning a quart of oil every 5300 miles. One would think that if I had piston slap that she'd be pushing a little more oil than that.
Also, is is possible for the head gasket to be leaking in such a way that no coolant or oil is leaking? I'm thinking of a situation where the head gasket may have a leak that merely allows combustion chamber gases to escape, causing a noise. Maybe the mighty backfire my wife caused blew a small hole in the head gasket.
Thoughts?
I'm pulling my hair out on this one!
Digger1
Old 05-13-2006, 08:49 PM   #9 (permalink)
Digger1's Avatar
Update on my knock.....it is still there.
Just had an idea though. Does anyone think that the big backfire my wife caused could have bent a valve stem? Will a bent valve stem cause a knocking noise?
Thanks, all!
Digger1
Old 07-03-2006, 11:20 AM   #10 (permalink)
1987 DX 5-speed
View nitrous3sfe's Photo Gallery
It would probably worth while to get a cheapie oil pressure gauge from Walmart and see if you are getting good pressure. Your oil pressure light will not go on unless you are at super low pressure.
nitrous3sfe is offline   Reply With Quote
Old 07-03-2006, 05:02 PM   #11 (permalink)
View 99sleeper's Photo Gallery
Hey buddy i kno what u mean....my family friend is a mechanice and we just got done unhooking the enitre damn engine.....i had the same knock nosie out of the blue one day and bout 3 days later it got louder and 3times faster........i tried to make it to the dealership and i made it but i wouldnt get any real power when i pressed the gas.....dealership said i needed a new engine and they qouted me $6350.....HELL NO!!!.....so got it towed home and now me and my friend are in the process of taking the head off....he tested my pressure int he cylinder i believe and they were all in the 120's expect the one that looks wet from oil which was 185......so to make a long story short.....brother get it looked at FAST....or you will be faced with what im goin thru....no ride for the 4th week now!!!!!.....o yea i got pics, i'll post
99sleeper is offline   Reply With Quote
Old 07-03-2006, 05:15 PM   #12 (permalink)
4th Generation
correction to my last post...i believe it was the valve pressure he checked not the cylinder pressure
Old 07-03-2006, 05:18 PM   #13 (permalink)
Toyota Parts since 1981
Gameroom cash: $148255
View DOHCammer's Photo Gallery
Does the engine still idle well? It sounds like you might have a broken exhaust valve spring, but that would probably cause a rough idle and a put-put sound in the exhaust. If that's not the case, then I'd drop the oil pan and check those rod bearings! One more thought, I've mistaken an exhaust manifold leak for a rod bearing noise on this style engine before. Take the exhaust shield off and make sure the nuts are tight.
05 Highlander V6 AWD
170K miles young
07 Camry SE V6 SOLD!!
TRD Dual Exhaust & Air Filter
DOHCammer is offline   Reply With Quote
Old 08-20-2006, 09:52 PM   #14 (permalink)
Digger1's Avatar
Exclamation
Nitrous,
Good idea, for peace of mind if nothing else.
Thanks!
Digger1
Old 08-20-2006, 09:55 PM   #15 (permalink)
Digger1's Avatar
Exclamation
99,
I appreciate the info. However, my Camry has now gone 22K miles with the noise I detailed in the first post of this thread.
My Dad says I need to turn up the radio when I drive the car.
Digger1
Fooling the ECM - sharing 1 good knock sensor for 2 ECM inputs Vibroseis Camry & Solara Lounge 14 10-05-2011 10:39 AM
a long rant to update some things... 95WhiteCamry Off Topic 8 11-06-2005 06:00 PM
Suggestions for fun cheap things to do on a 99 Corolla gspatta@worldne Archived Corolla threads 6 07-24-2005 12:33 AM
Attenuating Knock signal? JoeB Hardcore Tech and Competition 10 04-17-2005 02:35 PM
