2nd Gen Tire wheel combos? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-09-2002, 10:03 PM   #1 (permalink)
View DIRTBIKEZ's Photo Gallery
What size tires and wheels are you guys running on your cars? Does anyone know maximum width and/or overall diameter that will fit? Standard offset of stock wheel? Pics would be appreciated. Thanks.
DIRTBIKEZ is offline   Reply With Quote
Old 12-09-2002, 10:34 PM   #2 (permalink)
1990 JDM Camry Vista
StickyDilJoe's Avatar
View StickyDilJoe's Photo Gallery
Re: 2nd Gen Tire wheel combos?
225/35/18....someone once told me that 225's would never fit a gen 2 Camry. Some people still doubt me. Maximum width you can go at stock offset (+38) is 225/35/18. Anything else would rub the strut or fender well. As for as wheel size goes, you're looking at maybe running a 18x7.5 at the most cuz then you run into issues of rubbing and what not.
StickyDilJoe is offline   Reply With Quote
Old 12-09-2002, 11:11 PM   #3 (permalink)
View 1987camry's Photo Gallery
Wow, those are big! More power to ya! By the way, what kind of suspension do you have (i.e.- The struts might hinder a larger diameter tire.)?
I just have 15x6.5 Konig Caffeine wheels ( http://www.autotire.com/images/caffeine.gif ) with 205/50/15 tires. The car might look a little nicer with those Intrax 1.5in. drop springs, but I don't have the money (or that much of a desire).
My car isn't old, it's aged to perfection.
1987 Camry, 3S-FE, 5-speed, white/maroon, 15" Konig, Kumho 712 rubber, KYB Gr-2, more to come...
1987camry is offline   Reply With Quote
Old 12-10-2002, 02:03 AM   #4 (permalink)
I'm running Intrax springs with KYB GR-2 Struts. For a V6, I think it's a pretty sh*tty set-up cuz the ride is awful (35 series tires don't help much either). Gonna go with Tokico's next. The drop looks alot lower cuz the V6 is heavier. But for 4 cylinder guys, clearance shouldn't even be an issue since it sits considerably higher.
Old 12-10-2002, 03:22 AM   #5 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $307175
Well, I'll let you use my 16" rims and 50 series tires when your not at shows, how about that? (well, if we trade, that is :wink: ha). I'm running 205/50/16 with 7" wide rims and 38mm offset. The only time I had rubbing was when my whiteline front bar wasn't correctly adjusted. The caster was so far off that I was scraping the FRONT of the wheel well... ouch. But its all fixed now.
Joey, can you turn fully lock to lock without rubbing? What about low speed really tight corners? Have you rubbed yet? If you haven't, that's awesome!
btw, did you ever sell your old 17s?
-Charlie
Old 12-10-2002, 02:28 PM   #6 (permalink)
-Charlie
Strangely enough, I have never rubbed the fender at all at high speeds. If you saw the car in person, it would look like I would rub cuz the drop is so low in the front. The only time I rub is when I do u-turns and it rubs the inside plastic piece. But I had the problem when I was running 215/40/17. So it's not really and issue with the tires.
I still have the 17's. You can have them for $750 with Falken tires if you want them... :P
Old 12-11-2002, 01:23 AM   #7 (permalink)
white90dx's Avatar
Damn... I wish I wasn't saving up for the down payment on a WRX... I'd take 'em right now. 8) Then again, selling my wheels and tires I could make a little money back... oh... jeeze. So tempting. I wish I could do it.
-Charlie
Old 12-11-2002, 02:24 AM   #8 (permalink)
What type of wheels are we talking about here?
Old 12-11-2002, 04:20 PM   #9 (permalink)
Email me.... lsrprototypez@aol.com
