Need some advice on Timing belt tension, green or silver spring? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-02-2006, 11:31 AM   #1 (permalink)
View blueapple's Photo Gallery
Question Need some advice on Timing belt tension, green or silver spring?
I read on the toyota repair manual posted on this site about setting the timing belt tension.
It says use the green spring, rotate the crank-shaft 1 7/8 revolution, stop at 45 degree, then tighten the pulley bolt.
It also mensioned something about silver spring earlier, but didn't say anything about what is it for. It's got higher spring constant, but what is it for? new belt? used belt?
and, is the spring force alone really enough? I know my question sounds stupid...
Could anyone who's done the job give me a detailed and correct method of getting the right tension?
Thanks!
blueapple is offline   Reply With Quote
Old 01-03-2006, 05:17 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
The spring sets the tension. After the bolt for the tensioner is tightened, the spring does nothing.
As for the green or silver spring, I don't know and don't worry about it. I just install everything and torque the tensioner bolt to spec.
"Skoolin' the unlearned!"
My Timing Belt Job (Pics) 56k go away Ken4 Camry & Solara Lounge 113 05-18-2011 09:06 AM
Low RPM buzz/vibration after Timing Belt Change---What did I do wrong? shackelton Camry & Solara Lounge 8 07-02-2010 09:52 PM
Corolla VE 1999 need timing belt? skyline2k Introduce Yourself Here 4 05-26-2007 09:23 AM
Idler tension spring mystery greggf Camry & Solara Lounge 2 03-29-2005 06:13 AM
5SFE Rattling noise on Right side, Timing Belt Service needed !!! TRD_Rob 3rd & 4th Generation (1992–1996 & 1997–2001) 2 04-09-2004 11:44 AM
