Front Strut Bar Only? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-04-2006, 08:01 PM   #1 (permalink)
View Kal_Cougar's Photo Gallery
Gen5 Front Strut Bar Only?
Hi,
I'm looking to improve the handling characteristics of my '03' LE. I just want less body roll and more "crisper" cornering when turning. Looking underneath at the rear I discovered that there is already a sway bar factory installed. Would just the addition of a strut bar up front do? Would an aftermarket sway bar make a difference?
Kal_Cougar is offline   Reply With Quote
Old 01-04-2006, 08:19 PM   #2 (permalink)
HID/Retrofit Expert
white3ch0c0late's Avatar
iTrader Score: 7 reviews
View white3ch0c0late's Photo Gallery
Every car has a rear sway bar from factory. If you didn't have a stock sway bar, you'd probably flip over. An aftermarket sway bar will make a world of difference in handling.
2009 Audi TT 2.0T --- THE BEAST!
2002 LE 4Cyl --- Gone, but not forgotten. 06/28/09
Glaring blue HID bulbs are NOT classy, and don't make your car look nice, no matter what that kid in the Civic told you.
white3ch0c0late is offline   Reply With Quote
Old 01-04-2006, 09:33 PM   #3 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
just a tower bar alone is very miniscule in performance. rear sway bar will do wonders. shocks and springs will do even more.
WhiteRabbit is offline   Reply With Quote
Old 01-04-2006, 09:38 PM   #4 (permalink)
Thanks for the reply,
So looking towards the least costlier option, would it be enough to:
a) install a front strut brace along with using the factory sway bar
or
b) remove and replace the factory sway bar with an aftermarket one, foregoing the front strut brace.
Thanks
Old 01-04-2006, 09:45 PM   #5 (permalink)
Thank you for your prompt responses,
Looks like for now I will be replacing the rear sway bar with one from TRD or Whiteline.
I guess when finances allow me to, then I will be looking into getting front strut brace.
Thanks
Old 01-04-2006, 09:57 PM   #6 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Incorrect. Quite a few Gen 2's here in Australia don't have RSB's...
JetspeedCamry is offline   Reply With Quote
Old 01-04-2006, 09:59 PM   #7 (permalink)
TN's furry friend
yea, the rear sway bar will definitely give you more bang for your buck.
Old 01-05-2006, 01:14 PM   #8 (permalink)
FLIP'N THE G-5 WHIP
RICO8458's Avatar
View RICO8458's Photo Gallery
Gen5
I installed a front strut tower brace. i see the difference immediately. i can now take highway exit ramp turns at 65 to 70 miles an hour with greater smoothness than before. before the car would sway too much and i had to brake it down. now i can smoothly handle the g-forces... not bad...
Got the 50 on my jock cause my G-5 is so Hot...
2005=5.5 2AZ-FE, 2.4L DOHC 16-Value VVT-i, 4CYL, 160hp
RICO8458 is offline   Reply With Quote
KYB ( any non OEM ) Strut mount for Gen3 Camry? Front? blueapple 3rd & 4th Generation (1992–1996 & 1997–2001) 2 12-26-2008 11:36 PM
Front strut tower brace bar for Gen. 4? kenratboy Camry & Solara Lounge 8 11-19-2005 11:04 AM
front strut bar uptownwest Archived Corolla threads 2 02-13-2004 04:10 PM
Front Strut Tower Bar EasyE Camry & Solara Lounge 0 07-18-2002 12:58 AM
My new front upper strut bar :D CorollaKen Camry & Solara Lounge 3 08-04-2001 01:08 AM
