engine starting problems. please help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-11-2002, 08:25 PM   #1 (permalink)
View trdG's Photo Gallery
this recently started happening more and more...what happens is that when i turn the ignition, absolutely nothing happens! i would turn it all the way, and the car would react one little bit, nothing, not a single noise or antyhing. just now, when i went outside, i couldnt even turn the key in the ignition, like as if something is blocking it...please help, this is getting annoying, especially when i gety out of the movies with my g/f!
trdG is offline   Reply With Quote
Old 12-11-2002, 08:44 PM   #2 (permalink)
View Ken4's Photo Gallery
Maybe your chip is faulty. Use your spare key to see if it works.
If you cant turn the key at all, could be the steering lock.
Ken4 is offline   Reply With Quote
Old 12-11-2002, 08:45 PM   #3 (permalink)
Oomp loompa doopidy doo..
spills1969's Avatar
View spills1969's Photo Gallery
I had this problem a few time. It cud be something as small as the battery cable isn't tight enough. Believe me, something so little can cause that even if you think its tight, tighten it down more. One the other hand, it cud be the neutral start switch. I don't know where or even if cams have one but I know my friend has an 88 bronco and he had that problem and his neutral start switch was broken. Your car wont start (if you got an auto) unless its in park or neutral.
It cud be a variable of things. Best bet is to take it to a small town mechanic that doesn't charge too much for labor and have him look at it and tell you whats wrong with it. That way if its something small you dont have to pay him for something that u cud do. Is there any electrical currents goin on? can you turn on your headlights, and if you can are they really dim? if they are dim it cud be your alternator. Note* I am not a car EXPERT but i know my way around my cam. Like i said, i eud advise you to go to a mechanic, since they know what they're doin. Hope u get it fixed
http://www.cardomain.com/id/manwhorecamry
Nitrous is like a hot woman with STDs. You wanna hit it, but you're scared of the consequences...
spills1969 is offline   Reply With Quote
Old 12-11-2002, 10:11 PM   #4 (permalink)
i have a manual car, and no, no sign of electricity when i turned the key...also, i tried with the spare key, it also wont turn...il try to tighten the bolts pretty tight and ill tell what happens, thanx for the input.
Old 12-12-2002, 12:53 AM   #5 (permalink)
rayray's Avatar
View rayray's Photo Gallery
i had the same problem just recently. turned the key... nothing... no response at all. boosted the car... started no problem. got the battery tested... it was perfect. went home and cleaned the posts and battery terminals of corosion (there wasn't much there).
turned the key... vroom... started no prob.
check your posts and terminals. make sure there's clean and direct contact.
-rayray
rayray is offline   Reply With Quote
