Screeching noise from belt.. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-25-2001, 10:57 AM   #1 (permalink)
Banning is an art.
Silver Streak's Avatar
View Silver Streak's Photo Gallery
There's a screeching noise coming from that belt connected to the alternator...I"m assuming it's the accessory belt. Anyway, just wondering why it's so loud? I haven't had any engine work done since August (timing belt, plugs changed) and it's just started recently.
Any advice on why it's so loud? Does the belt need to be adjusted?
Silver Streak is offline   Reply With Quote
Old 11-25-2001, 12:25 PM   #2 (permalink)
Turbo-Yota power
Jzs147-RR's Avatar
View Jzs147-RR's Photo Gallery
What you should do is inspect your belt and then check the tension of it.If you need to change it its around 100$ ,i had that type of noise comming from my belt on my Accord back in 1996 when it was new and what hapend was it got loose and started to selfdestruct.Maybe you could try some belt lube ,they sell it at Canadian tire and it will help shut up that belt if its just dry.Anyways i hope i helped keep me informed.. :smile:
5sfe powered turd ...
Jzs147-RR is offline   Reply With Quote
Old 11-25-2001, 02:07 PM   #3 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
1.Try lubing all the pulleys that are around that area.
2.Alternator might be staring to show its age
TN Map - Add Yourself
Phi is offline   Reply With Quote
Old 11-25-2001, 04:50 PM   #4 (permalink)
Banning is an art.
Hmmm, I guess I'll try the lube thingy first...if that shuts it up, I'll be happy. I guess I can try to check the tension, but I know I won't be able to get an accurate measurement without one of those tensioner thingys.
Phi-you're car's a 92? I thought it was a 93?
Old 11-26-2001, 11:15 AM   #5 (permalink)
View speedemn's Photo Gallery
Phi's always had a 92.
2003 BMW 540i 6-spd
2008 Toyota Rav4 Limited V6
2005 Mazda 3 Sport GT 5-spd (just sold)
1995 Nissan Maxima SE 5-spd... Best ET: 13.8... Best trap: 99mph (Gone)
1993 Toyota Camry LE (Gone)
speedemn is offline   Reply With Quote
'93 Camry; engine noise and RPM questions Vibroseis 3rd & 4th Generation (1992–1996 & 1997–2001) 1 07-15-2002 09:35 AM
Engine noise on a 1990 Camry DX Sensenig 1st & 2nd Generation (1983–1986 & 1987-1991) 0 07-15-2002 08:06 AM
99 Corolla Drive Belt Noise bedrock4x Archived Corolla threads 2 04-08-2002 04:45 PM
Removing A/C from the belt route on V6 DS - TTCC General Discussion 9 02-06-2002 10:31 AM
88 Camry making horrible metal to metal engine noise Danielson 1st & 2nd Generation (1983–1986 & 1987-1991) 2 10-05-2001 02:07 PM
