Help Fire ...what Is This Thing ?negativeground? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-06-2006, 11:31 PM   #1 (permalink)
Pabloso
project92camry's Avatar
View project92camry's Photo Gallery
3rd Generation Help Fire ...what Is This Thing ?negativeground?
WELL I HAD A FIRE IN MY CAR UNDER THE PASSENGER SEAT IN MY 92 CAMRY 5SFE. IT CAME FROM A BLACK BOX WITH 2 HARNESSES . IT SAYS 12 VOLT NEGATIVE GROUND ON IT . WHAT IS THIS AND WHAT IS IT FOR ? I INCLUDED PICS . BTW NOW THE RADIO WONT WORK , DOME LIGHTS AND CLOCK MEMORY WILL NOT HOLD TIME . LOOK AT PICS ?
project92camry is offline   Reply With Quote
Old 01-06-2006, 11:34 PM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
It looks like the stock external stereo amplifier.
Can you get a better pic of the plugs in the 2nd pic?
As for the clock and dome light, the fire probably blew the fuse for them. I believe they all share the same fuse. Your cig lighter might not work either.
2007 Camry 2.4L 5M
Old 01-07-2006, 01:44 AM   #3 (permalink)
Cressida nut
Gameroom cash: $248745
View kamesama980's Photo Gallery
under the pass seat? isnt the seat control is it?
i say external amp too.
'90 Cressida, 7M-GE, M5 (2JZGE-T coming)
'91 Toyota Pickup, 22R-E, M5
'90 Suzuki VX800
"You don't get to judge me for how I fix what you break"
kamesama980 is offline   Reply With Quote
Old 01-07-2006, 01:48 AM   #4 (permalink)
Still confused...
95WhiteCamry's Avatar
iTrader Score: 7 reviews
View 95WhiteCamry's Photo Gallery
yes, it's the fujitsu ten stock amplifier.
"live in the moment, forget the past and ignore the future"
Originally Posted by white3ch0c0late
Yes, Alex is the resident woman-problems guy here at TN... take his advice...
'95 i4 camry sedan -> wrecked june of 2006 by a girl who couldn't drive
'95 v6 camry coupe (dropped, rimmed, front end converted, tinted and debadged) -> current
95WhiteCamry is offline   Reply With Quote
Old 01-07-2006, 01:55 AM   #5 (permalink)
HID/Retrofit Expert
white3ch0c0late's Avatar
View white3ch0c0late's Photo Gallery
^Yup yup. And touringcamry is right. The clock and dome light share the same 7.5A fuse. Replace it, and it should all work again.
2009 Audi TT 2.0T --- THE BEAST!
2002 LE 4Cyl --- Gone, but not forgotten. 06/28/09
Glaring blue HID bulbs are NOT classy, and don't make your car look nice, no matter what that kid in the Civic told you.
white3ch0c0late is offline   Reply With Quote
Old 01-07-2006, 08:35 AM   #6 (permalink)
Lex Zues!
RedPhoenix's Avatar
iTrader Score: 12 reviews
View RedPhoenix's Photo Gallery
the fuse is labeled dome btw.
Sold ^
Originally Posted by dysk8forlife
supercharger whine>girlfriend whine
RedPhoenix is offline   Reply With Quote
Old 01-07-2006, 12:02 PM   #7 (permalink)
Pabloso
3rd Generation
would The Stock Amp Not Working Have Anything To Do With Hooking Up A Aftermarket Radio ??? Thanx For All The Help U Guys and nice job on ur headlights REDPHOENIX .
Old 01-07-2006, 12:46 PM   #8 (permalink)
What exactly did you do? You hooked up an aftermarket radio...but did you bypass the stock amp? How did you install it?
Also before you replace the fuse, make sure there's no other problem than the amp that caught fire. Make sure no other wires are burned or damaged so you don't get a short and blow the fuse again.
2007 Camry 2.4L 5M
Old 01-07-2006, 12:57 PM   #9 (permalink)
Pabloso
I Didnt Install A Radio Yet. I Was Woundering If The Stock Amp Would Have Any Effect On Installing A Aftermarket Radio? Would I Still Need To Buy A New Stock Amp And Run It To The New Radio Or Just Remove It All Together.
Old 01-07-2006, 01:52 PM   #10 (permalink)
For aftermarket radio, the stock amp is not required. The amp is there because some Toyotas, usually those with premium sound system, do not have an amp in the radio itself. It is usually not compatible with aftermarket radios and most aftermarket radios have built in amps already.
2007 Camry 2.4L 5M
Old 01-07-2006, 03:50 PM   #11 (permalink)
View warlock's Photo Gallery
well sence you have it out you can see all the wires going to the amp. just plug then into each other. thay only fit to the right ones so you can mess it up.and then it will send to signal to the speakers.
94 Scepter 1MZ-FE
< TN Type [R]ice Club>RICERS UNITE!! Join Type R..latest faction of TN!!
.....http://www.toyotanation.com/forum/sh...d.php?t=105457
warlock is offline   Reply With Quote
Old 01-08-2006, 12:37 AM   #12 (permalink)
Pabloso
3rd Generation
Ok Cool .. Thanx Alot Touringcamry You've Been Alot Of Help.
Old 01-08-2006, 01:24 AM   #13 (permalink)
Pabloso
3rd Generation
Whats the one thing you look for in your mate? jhbhatia Off Topic 50 04-26-2006 08:38 PM
05 Tc Catching On Fire Today redheadedkittu 1st Generation (2005-2010) 20 06-10-2005 02:29 AM
Death by fire of my 2001 Camry! caspah 3rd & 4th Generation (1992–1996 & 1997–2001) 31 12-12-2004 09:14 PM
BURN BABY BURN...My college caught fire tonight! ASG14 Off Topic 12 11-20-2004 10:25 AM
Ferrari/ Maserati Dealership Fire (Pics) L-TunedIS300 Off Topic 34 11-15-2004 09:22 AM
