axel removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-08-2006, 08:20 AM   #1 (permalink)
View blue dog's Photo Gallery
axel removal
the axel is out of the hub snap ring is out and the lock bolt is out can not get the axel out of the trans.what is the way to get the axel out? this is on a 1997 camry with 4 cyl auto trans thanks for any suggestions.
blue dog is offline   Reply With Quote
Old 01-08-2006, 08:51 AM   #2 (permalink)
View vinscamandgn's Photo Gallery
3rd Generation
Are you trying to remove the passenger side axel?, If so you already removed that big snap ring and the retaining bolt, it should slide out, but the problem is that the axle bearing bonds together to the motor mount, making it really hard to remove, so what i did was remove the axle with the motor mount and then i was able to seperate them, with a liltle help with the tourch on the work bench, the when i re-installed the new axle i applyed anti-sieze on the bearing b4 i slide it in.
vinny
1992 camry,2.2l,babyblue,17in lex 430 wheels
vinscamandgn is offline   Reply With Quote
Old 01-09-2006, 06:57 AM   #3 (permalink)
View noodlerooney's Photo Gallery
I tried removing the rear motor mount for pass side axel on 94 Cam and could not clear the pins on the mount going into the engine, not enough play on axel going into trans. I ended up disassembling the old shaft at the inner boot and replacing with new axel to this point. Since my problem were the boots themselves, no problem. This pass. side axel is a real b**ch. The axel carrier bearing rusts itself to the support (rear engine mount). I also have a 2000 Solara, and it also has this design.
vinscamandgn: How did you clear the rear engine mount pins?
00 Solara SLE V6 1MZ-FE, 16.5K miles "Garage Queen"
94 Camry LE I4 5S-FE
noodlerooney is offline   Reply With Quote
Old 01-09-2006, 05:20 PM   #4 (permalink)
3rd Generation
i think i pryed against the mount itself to gain the clearence. it was a bitch and i would never wanna do it again. but as my luck has it i'll be removing the axle to remove the rear motor mount, but i did put anti-sieze on the bearing, so im hoping it comes out with ease.
vinny
Old 01-11-2006, 06:46 AM   #5 (permalink)
I was thinking that if you remove the carrier bearing locking bolt, PB blast the carrier bearing, and drive the car around for a while, you might get lucky and have the bearing start to spin in the carrier. It would now be relatively easy to remove the carrier bearing/axel since the rust weld has been broken...just an idea...
TACO 05' Front-end Plastic Removal greystoke 2nd Generation (2005+) 1 02-28-2008 12:09 PM
1997camry right axel blue dog Introduce Yourself Here 0 01-07-2006 12:26 PM
95 Camry Drivers Side Axel SeanGTS 3rd & 4th Generation (1992–1996 & 1997–2001) 4 12-20-2005 08:22 AM
rear axel backing plate and bearing removall??? !!? subliminaltrips 89-95 Toyota Pickup/Hilux 5 11-27-2005 10:04 AM
Need Help On AXel for 98 camry magic651 Hardcore Tech and Competition 3 03-29-2004 10:39 PM
