Wagon: Rear Window Washer - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-08-2006, 02:34 PM   #1 (permalink)
View chasman's Photo Gallery
2nd Generation Wagon: Rear Window Washer
Hi All,
Our rear window washer currently does not work in either the continuous or intermittent wipe modes.
The washer first failed to operate in the continuous mode several years ago. Since then, we would have to first use the intermittent mode to wash the window, then switch to the continuous mode to wipe the window until it was dry.
Is this due to the switch (84653-32030) or the rear pump?
Thanks!
Chasman
202k one-owner
87 I4 Camry Wgn
ES250 Strut Brace, Tokico Blue, Ceramic pads
Falken ZE-512, Goodyear Eagle UltraGrip H-rated M&S
chasman is offline   Reply With Quote
Old 01-08-2006, 05:41 PM   #2 (permalink)
Grumpy, but good at it
View te51levin's Photo Gallery
I think due the high likelyhood of internet misdiagnosis, this is something you'll want to check on the vehicle. Make sure you have power to the switch when you should. Make sure the switch functions as it should and sends power out the correct terminal when you press it. Make sure that when you send power out through the switch, it actually gets to the pump. And make sure that when the pump gets power, it does its job. Or do it the easy way and start at the pump with a test light: if you have power to the pump but it doesn't work, well, you need a pump. If not, you can chase the problem upstream.
te51levin is offline   Reply With Quote
Old 01-08-2006, 06:33 PM   #3 (permalink)
2nd Generation Any Wagon GEN2er had this problem?
Hey te51levin,
Agreed. However, if some other GEN2er has had this problem before (like "low-fan speed desn't work" thread), such experience could shorten the time to troubleshoot the cause.
If not, your troubleshooting guide for this specific issue will come in very handy indeed!
Thanks again for all the help!
Chasman
202k one-owner
87 I4 Camry Wgn
Old 01-08-2006, 11:40 PM   #4 (permalink)
Originally Posted by chasman
Hey te51levin,
I guess I'd be more insightful if our wagon had suffered the same malady and I'd have been forced to investigate...
I'm betting on a blown fuse, pinched/broken wire during aftermarket stereo install, or, since the problem at first varied with switch position, the switch itself.
Old 01-09-2006, 06:07 AM   #5 (permalink)
2nd Generation Perhaps replace the switch?
Hey te51levin,
  • The fuse is good - Both the front & rear wipers/washers are on the same fuse and they all work except the rear washer.
  • Original factory stereo
  • My guess is also the switch for the reason you state. I just didn't want to buy a switch on this hunch and then find it was the pump. But, since the switch hasn't operated the washer function in the intermittent mode for years, maybe replacing the switch is the best first step? If I'm lucky, it will solve the problem. If not, I'll have replaced a switch that has been 75% operational, and I then can rule it out - thus suggesting the pump or its wiring.
Thanks again!
Chasman
202k one-owner
87 I4 Camry Wgn
Tinting rear window.....(and removing old tint?) redgtxdi Camry & Solara Lounge 2 10-19-2005 06:34 PM
Double cab slider rear window. Tom W. 2nd Generation (2005+) 10 10-09-2005 07:23 PM
rear power window land5150 Camry & Solara Lounge 3 10-05-2005 11:39 AM
Where can I get Celica Rear Window Louvers in the the UK?? b_boy02 Celica Forum 0 02-26-2005 12:56 PM
Drift Setting help for GT3 I hate Toyota Corp :( Off Topic 3 11-10-2003 10:36 PM
