Help. Oil on spark plug threads. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-11-2006, 06:43 PM   #1 (permalink)
View Ken4's Photo Gallery
Whenever I remove my sparkplugs, I find oil on the sparkplug threads. Will changing the grommet stop the oil leak? Do I have to remove the valve cover to access the grommets? Mine is '00 camry 2.2L with 92,000km. Comments appreciated. Pic below:
Ken4 is offline   Reply With Quote
Old 01-11-2006, 07:02 PM   #2 (permalink)
OMNI's Avatar
View OMNI's Photo Gallery
I did it on a 93 v6 simply because I was doing the head gasket and I had to remove the valve cover (it was apart anyways). you are going to need a seal puller as they can be kinda stuck in there, sears has one or harbor freight has a cheaper one. pull out the old one, lube and tap in the new one with the right sized socket. get a haynes manual.
hoi hoi
OMNI is offline   Reply With Quote
Old 01-11-2006, 07:24 PM   #3 (permalink)
errr....so does changing the grommet stop the oil leak on the sparkplug threads?
Old 01-11-2006, 07:27 PM   #4 (permalink)
Moving Forward
View Cyorke's Photo Gallery
Sometimes it will but in my experience you will most likely have to remove the spark plug tubes and reseal them.
IS oil standing in teh tubes or is it just a slight amount. If oil is standing I can almost gaurantee the tubes need to be removed and resealed. We used to do it on a weekly basis when I worked at the Toyota dealer. The funny thing is I cant remember ever replacing the grommets though.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 01-11-2006, 07:43 PM   #5 (permalink)
There is oil only on the sparkplug threads below the crushable washer. I dont see any oil on the hex part of the sparkplug. Does that mean it's the grommet or the sparkplug tube?
Old 01-11-2006, 08:23 PM   #6 (permalink)
After sleeping on this, I think it is unlikely to be the grommet. The grommet is located on the valve cover, right? So its purpose is only to stop oil leak on the top of the valve cover. My oil leak is most likely from the sparkplug tubes. Couldnt find any info about sparkplug tubes from my Haynes Manual. But found info on how to install sparkplug tubes from the Toyota Tech Manual. Funny thing is they dont mention anything about removing the sparkplug tubes first. So I guess I will just use a pipe wrench and yank them out. Toyota Tech Manual says to use 'Adhesive' when reinstalling. What 'Adhesive'? Gasket sealant? Teflon tape?
Old 01-11-2006, 08:56 PM   #7 (permalink)
Moving Forward
I can not rememebr what the name of the stuff is that we used. If I saw it I would know it though. It is a small brown plastic jar with yellow writing on it. I think there is a picture of a gorilla on it or something like that. The lid has an applicator brush attached to it. oh yeah and it smells to high heaven. Like mineral spirits and all kinds of stuff combined.
I will see if I can get ahold of some of the guys I used to work with and get the name of it. It may be hard though since it has been several years since I worked there. You may be able to call your local dealer and see what they use for resealing them also. by the way I found this website with the tool for removing the tubes. http://www.kalyx.com/store/proddetai...975.0/file.htm
Or you can use a pipe wrench like you said or a set of curved nose channel locks is waht I used to use.
Chris
Old 01-12-2006, 01:15 AM   #8 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $407595
View atobe's Photo Gallery
i had a simliar problem with my gen2 the 3sfe i found one of my spark plug swimming in oil when i was checking up on them.. i replaced the valve cover gasket and changed all the gromets and there's no sign of oil of the spark plugs anymore. so i don't know.
Old 01-12-2006, 01:48 AM   #9 (permalink)
View Calvin327's Photo Gallery
Its just that your seals are busted very common for 3rd gen camrys. You will need to pick up all 4 seals, the valve cover gasket itself, 4 new spark plugs, and maybe the wires. Replace all of those and you should be fine. It just happens, I remember it happening to my 94 camry once. Replace it and it was fine.
Calvin327 is offline   Reply With Quote
Old 01-12-2006, 10:14 AM   #10 (permalink)
95% Biker / 5% Driver
Digger1's Avatar
View Digger1's Photo Gallery
Question
Chris,
Might you be talking about "Indian Head Gasket Shellac Compound?" This is a Permatex product.
BTW, that Kalyx web site rocks. I even found a cam pulley holder tool on there!
Digger1
"If you don't understand the technology you depend upon, you will someday be a victim of that technology."
Digger1 is offline   Reply With Quote
Old 01-12-2006, 12:20 PM   #11 (permalink)
Moving Forward
Damn your good. That is it. It has been about 8 years since I used the stuff so I couldnt rememebr for sure what it was. I just did a search on it and found a picture and yes that is it. so much for yellow and a gorilla. So many chemicals and sealants and adhesives in auto repair, it isnt hard to get them confused.
http://www.shop.com/op/~Permatex_IND...-prod-17016104
Chris
Old 01-12-2006, 04:35 PM   #12 (permalink)
Thanks for your replies. I think ThreeBond 1360E or 1360F might work too.
http://www.threebond.co.jp/en/produc.../1300list.html
Old 01-12-2006, 04:44 PM   #13 (permalink)
Gameroom cash: $304355
Before doing anything else, why not get a torque wrench and tighten the large 30MM nuts under the spark plug wires to 17 foot lbs. Check again for leaks in about 1000 miles. That stopped the leak on my 94 5SFE engine. It's been about 4 years now and still no leaks.
Mike
Mike Gerber is online now   Reply With Quote
Old 01-12-2006, 09:16 PM   #14 (permalink)
I think that was what started the leak, I tightened the sparkplug tube nuts to 33 ft-lbs as per Haynes spec to stop oil leaking on the valve cover gasket. So it must have put extra strain on the sparkplug tube seal and subsequently started leaking.
I managed to find 2 types of thread lock sealant from my neighbourhood store. Which do you think I should use?
Old 01-12-2006, 09:41 PM   #15 (permalink)
Nad1370's Avatar
View Nad1370's Photo Gallery
You can also use Toyota F.I.P.G. sealant.
Works real well.
There is a special tool that can take the tubes out w/out taking the valve cover off.
Can't remember the part # but a Snap-On truck should carry it.
If no luck...pipe wrench works well.
Nad1370 is offline   Reply With Quote
Oil in spark plug hole?? WhiteTrash2775 Solara 5 04-26-2010 06:31 PM
oil in spark plug it drips echo1 Archived Corolla threads 47 12-10-2004 01:46 PM
oil in the spark plug chamber trebor_9513 General Discussion 7 12-06-2004 10:43 PM
Oil on one spark plug bronzemaxell Camry & Solara Lounge 16 12-06-2004 09:08 PM
Spark plug wire boot ']['R][) camry Camry & Solara Lounge 10 04-18-2004 12:59 AM
