Drum Removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-11-2006, 11:37 PM   #1 (permalink)
trninhds's Avatar
View trninhds's Photo Gallery
Drum Removal
Having big problems with removing the passenger side drum to get to the lug stud. I Bought the Hanes manual and followed their directions and the thing still wont come off. I've tried using a rubber mallet to knock it loose but nothing. Is there some bolt or something that I need to removing ...Help me out fellas
trninhds is offline   Reply With Quote
Old 01-12-2006, 12:24 AM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Usually I take two 12 Metric screws and insert them in the holes there and tighten each one half turn at a time with a socket
On the back side of the drum, there should be something you can turn to retract the shoes so they don't bind the drum.
2007 Camry 2.4L 5M
Old 01-12-2006, 01:01 AM   #3 (permalink)
View 97&02camryleI4's Photo Gallery
make sure the parking brake isn't set
97&02camryleI4 is offline   Reply With Quote
Old 01-12-2006, 01:04 AM   #4 (permalink)
trninhds's Avatar
The E-brake is released and I followed the manual on how to loosen up the brake pads but it still wont come off, Could be rust????
Old 01-12-2006, 01:06 AM   #5 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $407595
View atobe's Photo Gallery
can you spin it freely? if you can then it's probbly got a groove and it's worn out in there.
Old 01-12-2006, 01:07 AM   #6 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $397085
View RningOnFumes's Photo Gallery
how hard are you whacking it with your hammer?
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is offline   Reply With Quote
Old 01-12-2006, 01:09 AM   #7 (permalink)
OMNI's Avatar
View OMNI's Photo Gallery
yea, I had to beat on that sucker pretty hard to get it off.
hoi hoi
OMNI is offline   Reply With Quote
Old 01-12-2006, 09:56 AM   #8 (permalink)
95% Biker / 5% Driver
Digger1's Avatar
View Digger1's Photo Gallery
TRN,
I agree with the hammer ideas above.
FWIW, whenever I get a new car in my garage, one of the things I do (among several other things) before the car even has 100 miles on it is to remove the brake drums and coat the mating surface (where the drum mates with the hub) with a THIN layer of Anti-Seize.
I'll also remove the drums (to give the shoes a look) every time I rotate the tires (about every 7K miles). At this time, I replenish the Anti-Seize.
I have no problems getting off brake drums since I started this regimen 25 years ago.
NOTE: If you overdo it on the Anti-Seize, you will foul your brake shoes and it will be time to buy some new ones....be careful!
Digger1
"If you don't understand the technology you depend upon, you will someday be a victim of that technology."
Digger1 is offline   Reply With Quote
Old 01-12-2006, 12:49 PM   #9 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140795
yeah, do what touringcamry said. mine were rusted on pretty tight last time i did my brakes and using those two threaded holes were the only way to get it off. but do turn each screw a little at a time as to pull it straight off and not have it bind.
ghettosled is online now   Reply With Quote
Old 02-03-2007, 03:28 PM   #10 (permalink)
View michaelzz's Photo Gallery
1994 Camry Brake Drum Removal
Lots and lots of Liquid Wrench. I was going to try the screw method but the 12 metric screws were the wrong size for my drum. I sprayed liquid wrench by the five lugs and in the 2 small screw holes. Using a hammer I tapped lightly back and forth on either side of the broken lug (I didn't want to side load the 4 good ones). This enable to drum to shift back an forth about an 1/8 inch. I did this for 5 minutes and the drum slipped off easily.
michaelzz is offline   Reply With Quote
Old 02-03-2007, 10:30 PM   #11 (permalink)
ASE Master, now Realtor
timebuilder's Avatar
View timebuilder's Photo Gallery
Spray PB Blaster around the center hub and studs. Let stand for three minutes. Strike with a heavy hammer using sharp blows to the drum (not the hub) between the studs at several places.
If the drum is severely worn, it may have a lip on the inside edge. Then you must use a piece of wire to hold the adjuster tang off the wheel while you back off the adjuster to pull in the shoes to clear the lip.
Courage...Honor...Conquer
timebuilder is offline   Reply With Quote
Old 02-04-2007, 08:25 AM   #12 (permalink)
View marc780's Photo Gallery
If all else fails, a big ol 3 jawed puller tool. The reason it won't come off is because there is a wear ridge on the inside edge of the drum, on the spot where the brake shoes do not touch the drum. (Once you get the drum off you will see what i mean). So its likely the drum will need to be replaced too.
Old 02-04-2007, 11:53 AM   #13 (permalink)
alotawatts's Avatar
View alotawatts's Photo Gallery
What year is your Camry ?
My 2001 4Runner rear drum surfaces have an edge on the inside meaning... you can beat your brains out getting them off. Look on the inside plate for in inspection hole. It may have a rubber plug in it. If so work though there with a brake tool or screw drivers to back of the adjusting mechanism. You can grind off the edge of the drum(s) surface so next time they will pop/hammer off.
alotawatts is offline   Reply With Quote
Old 02-05-2007, 11:53 AM   #14 (permalink)
ghettosled's Avatar
i hope the original poster got the drum off by now considering this thread is over a year old.
Old 02-05-2007, 12:34 PM   #15 (permalink)
Could be up on blocks!
Rear Brake Drum Removal... _2002TLRJAY_ Yaris, Vitz and Echo Forum 5 03-21-2011 10:41 AM
Drum Brake removal (How?) SolaraTRD Camry & Solara Lounge 5 07-21-2005 06:19 AM
Help me with my drum brakes!!! 89_3SFE Celica Forum 7 10-18-2004 10:43 PM
Drum to disk conversion - DONE kocho Camry & Solara Lounge 19 06-25-2004 04:30 PM
brake drum removal mykngdom4avvti Yaris, Vitz and Echo Forum 1 05-05-2004 08:40 PM
