Best way to run power wire to trunk?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-13-2006, 06:53 PM   #1 (permalink)
View Caver's Photo Gallery
Question Best way to run power wire to trunk??
Hi, I need to run power from the battery to the trunk for communication equipment in my 2006 LE V6. It looks like there is a path through the firewall where the main engine wiring goes through. Is this the best way or is there a better way that I have not found. BTW it is just two 10ga wires that need to be run. Also how do you get wires from the center console to the trunk? Thanks, Caver
Caver is offline   Reply With Quote
Old 01-13-2006, 07:24 PM   #2 (permalink)
Dominican Republic
Dj-torn's Avatar
View Dj-torn's Photo Gallery
Click my signature and go to the page where the amp instalation is. There you will see how i ran a 4 guage wire from my battery to my amp which is under the driver seat.
The pictures will explain better what i mean, and then from where i turn to go to the seat you continue along the rear door sill under the seat and into the rear.
Stock 2002 Camry LE: 2AZ-FE: VVT-i
Dj-torn is offline   Reply With Quote
Old 01-13-2006, 09:48 PM   #3 (permalink)
The Other White Meat
terrastrife's Avatar
pick your own damage on how to get though the firewall, in RHD vehicles its incredibly easy becasue the ecu loom is on the same side as the battery, then just run it though the kick panel, front door sill, rear door sill, hug the rear under the rear seat, and youre in the boot =)
terrastrife is offline   Reply With Quote
Old 01-15-2006, 10:56 PM   #4 (permalink)
Thanks for the help guys. I am running it nest to the ecu loom. Toyota leaves a path open there.
Caver
Old 01-15-2006, 11:19 PM   #5 (permalink)
N/A bites
Tercel GTS's Avatar
Why 2 10g wires?
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
remote wire spliced to power antenna? nobrainer Audio, Video, and Security - Tech 10 08-18-2005 02:26 PM
Can a Bad Plug Wire Cause Clogged Cat? mnwolftrack Camry & Solara Lounge 3 07-04-2005 08:01 PM
extra battery 97avalonxls Audio, Video, and Security - Tech 9 09-20-2004 12:09 PM
Need Help Identifying Power Wire for clock for '03 enginerd 5th & 6th Generation (2002-2006 & 2007-2011) 4 08-02-2004 12:28 AM
