CAN any one tell me what this tube does ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-13-2006, 09:11 PM   #1 (permalink)
View Flight23's Photo Gallery
2nd Generation CAN any one tell me what this tube does ?
as there is a small crack in it where it connects to the engine and I was wondering if i should
replace it , also has any one drilled or made holes in the bottom of there standard airbox to increase airflow doe this give any performance boost? ihave a 1988 v6 camry
Flight23 is offline   Reply With Quote
Old 01-13-2006, 09:16 PM   #2 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
my guess, the vacuum line. if theres a crack, id replace it.
is that engine bay yours? so clean
WhiteRabbit is offline   Reply With Quote
Old 01-13-2006, 09:19 PM   #3 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
That is an engine bay I could eat off of.
BlueFusion6851 is offline   Reply With Quote
Old 01-13-2006, 09:20 PM   #4 (permalink)
not my pic
this is jetspeed car but i dont have a digital camera
but we have the same model car
Old 01-13-2006, 09:50 PM   #5 (permalink)
The Other White Meat
terrastrife's Avatar
thats an emmisions related tube. were not allowed to vent valve gasse into the atmo so it goes back though the intake and into the car again, you can plug it up on the intake and put a mini breather on the valve cover though if you wanted.
ir just get some hose from home depot and replace it, nothing special, just ordinary rubber hose in the same diameter.
fyi, that is where bling bling oil catch cans go.
you can just duct tape it up if you wanted to too.
terrastrife is offline   Reply With Quote
Old 01-14-2006, 06:30 AM   #6 (permalink)
The 6"4 Viking
Zandro's Avatar
View Zandro's Photo Gallery
That tube is not a vacume hose it`s called the pvc valve, it is the valve cover ventilation
that directs the oil steam and water deposits back into the engine and improves emissions, it also prevents water emulsion in the engine oil.
Zandro is offline   Reply With Quote
Old 01-14-2006, 06:42 AM   #7 (permalink)
View Ken4's Photo Gallery
Looks like the bypass hose to me. PCV hose will be much closer to the intake manifold. During high vacuum, PCV hose draws in more air, so the make up fresh air comes thru the bypass hose. During hard acceleration or WOT, there is no vaccum in the intake manifold, so the excess blow-by gases in the crankcase have to be vented somehow, so now the bypass hose works in reverse, it vents crankcase gases out to the intake.
Ken4 is offline   Reply With Quote
Old 01-14-2006, 01:24 PM   #8 (permalink)
The Cool Guy
Super Kaioken's Avatar
View Super Kaioken's Photo Gallery
i agree with Terra. Its one of those Venting tubes. spits dirty stuff back in. I'm gonna put a mini breather on mine because i like the look of the small filter. MORE HP! hahaha j/k
-Custom 2.5in Cat-back Exhaust + Borla Muffler + Weapon R Dragon Intake + TRD Rear Sway Bar + TRD Springs + TRD Front Strut Brace
Super Kaioken is offline   Reply With Quote
Old 01-14-2006, 03:06 PM   #9 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
it's best to keep the hose on
with a breather, you'll actually lose some power, while creating more emissions
HaHa
Old 01-14-2006, 04:27 PM   #10 (permalink)
View GrantTPC's Photo Gallery
That about right... except the PCV valve is actually a separate part installed on the valve cover, the tube directs the vented gases back into the intake to be reburned..
In Canada if you are caught without that tube hooked back into that intake and are venting directly into the atmosphere atmosphere you get slapped with a pretty hefty fine..
As the engine runs the air pressure inside changes--besides the pistons pumping, all the other chambers in the engine have fluctuation of pressure as well. In the empty space under the valve cover the easiest way to equalize the pressure is to punch a hole in the valve cover. The PCV valve sits in this hole..... because under the valve cover are the cams and such that need lubrication lots of oil vapour is formed and that would normally get vented into the atmosphere.. to reduce this pollution the engineers that designed the emissions control systems redirect that vapour back into the intake to burn off the oil vapour during the course of combustion for power..
Since it is relatively a small amount oil it will not harm the engine, however, it does affect how well the gasoline it is mixed with burns and slightly reduce the power f the car.. People with turbo vehicles are especially at risk since this vapour effectively lowers the octane rating of the air fuel mixture... To get around this one could install a baffled oil catch can in-line to filter out the vapour and still keep the emissions system a closed circuit..
Chairperson, Toronto Prelude Club
1995 Honda Prelude SR, 1987 Toyota Supra (sold), 1988 Toyota Supra Turbo (sold), 1992 Toyota Camry, 2003 Honda CR-V
I still have too many cars..
GrantTPC is offline   Reply With Quote
Old 01-14-2006, 07:38 PM   #11 (permalink)
The Cool Guy
Unhappy
it does reduce power? how? isn't it just oil vapor? oil doesn't exactly burn in the fuel/air mixture? pretty confused here...
Old 01-14-2006, 08:10 PM   #12 (permalink)
TN Pussy Man
take a look at granttpc''s explanation above
HaHa
Old 01-14-2006, 09:32 PM   #13 (permalink)
there isnt a PCV on the front back of the v6 though..that im aware of.. its just open... i managed to poke a chopstick in all the way...
Old 01-14-2006, 11:23 PM   #14 (permalink)
The Cool Guy
From his explanation, it says it slightly reduces the power of the car if i hook it on my new intake. So why shouldn't i put a breather on it, instead of hooking it in my intake and therefore reducing power.
Old 01-14-2006, 11:58 PM   #15 (permalink)
Nad1370's Avatar
View Nad1370's Photo Gallery
This is just a plain engine breather tube.
Not emission related
Not power robbing or creating power.
You could put a breath filter on it but will be messy with oil coming off of it.
I'd suggest putting a Catch Can in between the tube and route it back to the intake.
This way the Can will catch the oil and not go in your intake.
Nad1370 is offline   Reply With Quote
Tube Step Pics Wanted: Silver Sport Access Cab TacoSport05 2nd Generation (2005+) 7 08-14-2005 11:23 AM
DIY Cold-Air Intake bondobondo Hardcore Tech and Competition 40 11-24-2004 01:41 PM
90 Camry LE V6 a/c orifice tube jORGE 1st & 2nd Generation (1983–1986 & 1987-1991) 0 08-10-2004 05:55 AM
Audiobahn Bass tube vs Bazooka Bass Tube planetdon Audio, Video, and Security - Tech 13 11-20-2003 10:10 PM
