Lighting Help and extra wire suprise
This is a multi part question:
I have an 04 with manual HVAC controls. I popped the control panel out, but it turns out that the part that makes it green is the filter with the little people printed on it (the one that shows where the air is going). Is there a cheap way to make a new one that is clear?
On the Radio, how do I determine which side of the smd led is + and which is neg. These suckers are small BTW.
Also there was a plug behind the HVAC control panel that was not plugged into anything and one behind the Headunit. I was wondering is anyone knew what they were for. I was thinking the one behind the HVAC was for the digital controls, which would make it easy to swap out. The one behind the Headunit might be for the multi display (mpg, crusing range etc). If I could get these two panels from a junker, and the wires were already there, that would be sweet. Anyone with any insight.
Last thing is that I had to remove the HVAC controls before I started prying on the vents. I was reading on this site to just start prying, but thats not the case, the lower one interlocks with the upper one.
