Smooth Shifts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-14-2006, 12:14 PM   #1 (permalink)
View sameer2601's Photo Gallery
4th Generation Smooth Shifts
I think i may have a problem with my tranny. i have noticed that when the gears changes from 1st to 2nd, the shift is not smooth. a jerk is felt. but it shifts smoothly thereafter 2nd to 3rd and fourth and vicevera. i have just had my tranny swapped and the shifting is same like my previos tranny (jerk from 1st to 2nd). is it normal with a 4cyl or something to do with the soneloid valve. the shifting is barely noticable in a v6. Is synthetic ATF good for the tranny and will it make shifting smoother. (The swapped tranny is around 40,000 miles)
97 camry le Auto
4cyl 128,000 Miles
sameer2601 is offline   Reply With Quote
Old 01-14-2006, 02:04 PM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
do you have TWO cables going off your throttle body? one is the throttle cable, the other goes to the transmission to tell it how hard to shift/at certain rpm.
LOOSEN this cable, there are 2 nuts, just spien the outher one clooser to the transmission loose, then the inner one to tighten it back up.
remember though the harsh shift is actaully better on the transmission as it spends less time "in between" gears.
terrastrife is offline   Reply With Quote
Old 01-14-2006, 02:33 PM   #3 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Search the forum for "free mods" series part 1
http://www.toyotanation.com/forum/sh...045#post485045
There will be the pictures of the cables.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Hajoca is online now   Reply With Quote
Old 01-14-2006, 04:28 PM   #4 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
may be your motor mounts. i had the same problem. then i found out my mounts were torn and had them replaced, not intending to fix the hard shifting, but it did. =)
WhiteRabbit is offline   Reply With Quote
Old 01-14-2006, 05:50 PM   #5 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
well the two suggestions above are what i'd do first before anything else. A transmission flush is very helpful as well (only if your fluid is dark/black.)
nodrogkam is offline   Reply With Quote
Old 01-15-2006, 12:09 PM   #6 (permalink)
Thanks a lot guys. i'll do the cable thing first and see the difference. will keep you all posted. what about synthetic ATF.
Old 01-15-2006, 04:47 PM   #7 (permalink)
TN's furry friend
^thatll help too.
Old 01-15-2006, 07:23 PM   #8 (permalink)
View jrock80's Photo Gallery
Mine had the same problem, turned out to be an issue with the valve body in the transmission. Just needed cleaned, runs good as new now.
jrock80 is offline   Reply With Quote
Old 01-16-2006, 03:47 AM   #9 (permalink)
well i had tried the cable adjustment the shifts are quicker now but still does not solve the hard shift from 1st to 2nd. secondly about the cleaning of the valve body, is it a DIY or a trip to the garage. where is it located.
Old 01-16-2006, 09:01 AM   #10 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
I have the 2005 LE 5-speed the same thing happend to me. It was a speed sensor in the trany.
BlackCamSe is online now   Reply With Quote
Old 01-16-2006, 09:49 AM   #11 (permalink)
Darkside Cut Me!!!
Originally Posted by sameer2601
......... about the cleaning of the valve body, is it a DIY or a trip to the garage. where is it located.
This will require draining the transmission pan and removing it.
DIY'able.
2004 RX330 Sport
2003 Cam I4 XLE
Old 01-16-2006, 12:25 PM   #12 (permalink)
you tightened the cable. loosen it.
Old 01-17-2006, 12:42 AM   #13 (permalink)
tightened it all the way to the rubber stopper (edge of the thread)
Old 01-17-2006, 12:44 AM   #14 (permalink)
nodrogkam's Avatar
Personally i wouldnt tighten the or loosen the cable to either extreme. I highly doubt that is good for the vehicle.
I adjusted mine a little bit and that made a noticible difference...going all the way tight or loose must make a HUGE difference.
I wouldnt recommend it.
Old 01-17-2006, 12:45 AM   #15 (permalink)
LE 5-speed. is it auto or manual
T100 MT Shifts Hard davet100 T-100 8 09-11-2005 05:16 AM
2000 Tundra shifts hard dimlay 1st Generation (2000–2006) 1 08-11-2005 05:12 PM
enigne rpm doesn't decrease between shifts mh808 2nd Generation (2005+) 11 07-05-2005 07:07 PM
Door Guard Fillers... Smooth Doors? ??? alleyway28 Camry & Solara Lounge 2 06-11-2005 11:39 AM
not a smooth ride KerTiZ Camry & Solara Lounge 2 05-19-2004 07:35 PM
