breaks - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-14-2006, 01:30 PM   #1 (permalink)
southern racer
View JLcamrydave's Photo Gallery
4th Generation breaks
My break light comes on and off all the time anyone know what it could be? maybe the master celender help plz bc my car is goin in the shop soon to get my gold line drop springs on and i want to kill two birds with one stone help gen 4 camry
JLcamrydave is offline   Reply With Quote
Old 01-14-2006, 01:37 PM   #2 (permalink)
HID/Retrofit Expert
white3ch0c0late's Avatar
iTrader Score: 7 reviews
View white3ch0c0late's Photo Gallery
Which brake light? The ABS light? Or the light that says, "Brake" ? 'Cause if it was the 2nd one, chances are that the e-brake wasn't disengaged all the way, and the sensor keeps on turning the light on and off at times thinking that its engaged, and at others thinking that its disengaged. And why not install the springs yourself? Its not a difficult job.
2009 Audi TT 2.0T --- THE BEAST!
2002 LE 4Cyl --- Gone, but not forgotten. 06/28/09
Glaring blue HID bulbs are NOT classy, and don't make your car look nice, no matter what that kid in the Civic told you.
white3ch0c0late is offline   Reply With Quote
Old 01-14-2006, 01:57 PM   #3 (permalink)
The Other White Meat
terrastrife's Avatar
if its been a while sinc eyour last brake pad change, your fluid level is 'low' so it goes on as the fluid sloshes around in the little container, messing with the level indicator sensor.
if you do top it up, make sure to remove some before changing pads.
terrastrife is offline   Reply With Quote
All 4 Disk Breaks Tankedcook Camry & Solara Lounge 13 01-12-2006 07:55 PM
breaks natoco1 Celica Forum 1 11-17-2003 11:27 AM
Squeaky Suspension and Breaks... FrankXT86 Camry & Solara Lounge 3 07-05-2003 05:47 PM
can i change my rear drums to rotor breaks ?? Zeek321 Hardcore Tech and Competition 7 10-25-2002 12:14 PM
Can i change my rear drums into rotor breaks?? Zeek321 Camry & Solara Lounge 2 10-16-2002 09:32 PM
