Lean Spark Plugs? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-15-2006, 06:16 PM   #1 (permalink)
View minime3's Photo Gallery
3rd Generation Lean Spark Plugs?
What do lean spark plugs indicate? All i could find out is that it might have something to do with air/fuel ratio, but what causes this?
minime3 is offline   Reply With Quote
Old 01-15-2006, 06:24 PM   #2 (permalink)
The 6"4 Viking
Zandro's Avatar
View Zandro's Photo Gallery
What engine do you have V6 I4?
Zandro is offline   Reply With Quote
Old 01-15-2006, 06:29 PM   #3 (permalink)
its a 4 cylinder, automatic
Old 01-15-2006, 06:35 PM   #4 (permalink)
The 6"4 Viking
Zandro's Avatar
Lean spark plugs can idicate a lot of things: too advanced ignition timing,
low octane rated fuel, wrong plugs (too hot) ect. since you have a cali
5S-FE engine there are emissions related things that could have failed too
resulting a lean mixture.
Old 01-15-2006, 06:40 PM   #5 (permalink)
i have the standard ngk which is recommended, the octane rate is 87 or the cheapest which should be right for my car. i dont know what advance timing ignition means, is that ignition too soon before fuel reaches engine? Someone told me that I have have bad fuel injectors so not enough fuel is getting in. Is that a valid reason too?
Old 01-15-2006, 07:33 PM   #6 (permalink)
View Gary_602Z's Photo Gallery
Vacum leaks, injectors and the list goes on! Take it to a good mechanic. Not just someone who wants to throw parts at it! Running to lean is not good on the engine.
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 01-15-2006, 09:37 PM   #7 (permalink)
View luisitol's Photo Gallery
run fuel system cleaner through your gas tank and injectors. I would suggest Lucas over STP. Also change out your fuel filter. And also have a shop, if you don't feel confident doing it yourself, check your timing. Once all those issues are taken care of you should be squared away.
'93 Probe GT - Daily Driver
'93 LE - Show Car - Coming SOON
luisitol is offline   Reply With Quote
Old 01-15-2006, 09:59 PM   #8 (permalink)
thanks, thats definitely something i could work with. The fuel filter was changed not too long ago but before i change it again, I will buy the smaller bottle of the lucas fuel and injector cleaner and see how it works first. I will keep you posted on the results. Hope it will do for me what it did for you.
How to change spark plugs on 1MZ-FE under 1 hour albertezza Camry & Solara Lounge 25 06-23-2011 08:51 PM
Denso Spark Plugs for 1MZ-FE ptycamry Camry & Solara Lounge 10 01-05-2006 02:26 AM
Iridium Spark Plugs!?!?!!? Matsu-Seo Yaris, Vitz and Echo Forum 6 12-03-2004 09:52 AM
spark plug wires + spark plugs aleks77 Camry & Solara Lounge 4 09-13-2004 02:08 PM
changed spark plugs... engine light came on. sexydarin Archived Corolla threads 2 10-30-2003 06:21 PM
