speedometer not working? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-15-2006, 06:25 PM   #1 (permalink)
View minime3's Photo Gallery
3rd Generation speedometer not working?
My speedometer stops working intermittently after a couple of minutes it starts to bob back up. It just lies dead at zero no matter how hard you accelerate. Its very unpredictable. Is this electrical or sensor problem? The rest of guages on the instrument panel seem to be reading fine.
minime3 is offline   Reply With Quote
Old 01-15-2006, 06:48 PM   #2 (permalink)
Still confused...
95WhiteCamry's Avatar
iTrader Score: 7 reviews
View 95WhiteCamry's Photo Gallery
after the needle goes back up, does it read correctly? if so, then it's an electrical problem. check the wiring harness for any breaks.
"live in the moment, forget the past and ignore the future"
Originally Posted by white3ch0c0late
Yes, Alex is the resident woman-problems guy here at TN... take his advice...
'95 i4 camry sedan -> wrecked june of 2006 by a girl who couldn't drive
'95 v6 camry coupe (dropped, rimmed, front end converted, tinted and debadged) -> current
95WhiteCamry is offline   Reply With Quote
Old 01-15-2006, 07:01 PM   #3 (permalink)
yes it does, where is this wire harness?
Old 01-15-2006, 07:05 PM   #4 (permalink)
1993 Camry XLE
HoboJoe's Avatar
View HoboJoe's Photo Gallery
Wire harness is behind the gauge cluster.
HoboJoe is offline   Reply With Quote
Old 01-15-2006, 08:32 PM   #5 (permalink)
sorry i'm more proficient in doing regular maintenance with my car and not too in tuned with the electrical aspects and its terms. Is the "gauge cluster" the instrument panel? How would I get access to this component. I did some researching and found that the speed sensor and the "cluster" might also be at fault. Does anyone have any idea where these parts are located? Thanks
Old 01-15-2006, 11:53 PM   #6 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
its probably not an electrical problem. either it would work 100% or nothing. i'd get a replacement speed sensor. the plastic gear on the sensor wears after a while, and after a while it wont work at all.
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 01-16-2006, 08:58 AM   #7 (permalink)
Pissed
View Camryamnesty's Photo Gallery
the guage cluster is the right behind your steering wheel, with all the gauges in it, i believe you have to remove the trim around it, and there is 4 bolts behind that 10 mm i believe its been so long since i had mine out.pull the cluster out, and check the wires that plug into the back of the cluster.
Camryamnesty is offline   Reply With Quote
2001 Camry speedometer and odometer not working joy603 3rd & 4th Generation (1992–1996 & 1997–2001) 2 09-04-2005 10:51 PM
1990 Camry Speedometer not working? Neatride2 1st & 2nd Generation (1983–1986 & 1987-1991) 2 03-31-2005 01:13 AM
MY SPEEDOMETER IS NOT WORKING farrk007 Supra Forum 2 02-11-2003 11:01 PM
Speedometer not working? Kristy Archived Corolla threads 1 01-20-2003 09:58 PM
