Dead dome light, trunk light, clock! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-15-2006, 06:34 PM   #1 (permalink)
View mwebb's Photo Gallery
Unhappy Dead dome light, trunk light, clock!
I recently "fixed" a sunvisor light on my 1998 Camry and during the process, I must have touched the positive and negative terminals. Now the interior dome light, trunk light, and clock are fried. Everything else in the electrical system seems perfectly fine. I replaced the "Door" fuse, but those lights are still dead. What other damage have I done besides the fuse?
mwebb is offline   Reply With Quote
Old 01-15-2006, 07:16 PM   #2 (permalink)
HID/Retrofit Expert
white3ch0c0late's Avatar
iTrader Score: 7 reviews
View white3ch0c0late's Photo Gallery
Its the Dome 7.5A fuse. Its blown. Replace it, and it'll all work.
2009 Audi TT 2.0T --- THE BEAST!
2002 LE 4Cyl --- Gone, but not forgotten. 06/28/09
Glaring blue HID bulbs are NOT classy, and don't make your car look nice, no matter what that kid in the Civic told you.
white3ch0c0late is offline   Reply With Quote
Old 01-15-2006, 09:01 PM   #3 (permalink)
V6LE_CAMRY's Avatar
View V6LE_CAMRY's Photo Gallery
check all you fuses again, even in the engine compartment.
V6LE_CAMRY is offline   Reply With Quote
Old 01-21-2006, 03:12 PM   #4 (permalink)
still problem with fuses and lights...
Thanks for the advice guys. I've checked all fuses....TWICE! As I said, I replaced the "Door" fuse and tested all 7.5A fuses, such as "Panel", etc. Also, nothing is labeled "Dome" or "Clock" or "Trunk light".
Any other suggestions?
Old 01-21-2006, 04:47 PM   #5 (permalink)
V6LE_CAMRY's Avatar
have you gone back and checked the wiring on that lighted visor? if every thing is o.k. there then the only two things that i could think is that a positive wire that feeds power to those things fried or it's unlikely that all the lights actually burned out
More light in the trunk DIY - by SnakeyeS and Brungold brungold General Discussion 73 02-04-2012 03:43 PM
Consumer Reports on HID Phi General Discussion 28 01-17-2007 08:23 PM
HOW to replace the light inside the trunk?? GEN4 leasaunce 3rd & 4th Generation (1992–1996 & 1997–2001) 27 08-28-2005 10:06 PM
dome light not working mazdaverx7 Camry & Solara Lounge 11 08-22-2005 03:40 PM
How do I power neon from trunk light? adsaba1969 Archived Corolla threads 6 05-22-2005 02:57 PM
