Engine noise... Help me plz - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-16-2006, 03:44 AM   #1 (permalink)
View syang's Photo Gallery
2nd Generation Engine noise... Help me plz
Hi all,
i'm having an issue with my 90 camry v6... when i drive the car it keeps on making a popping noise or knocking noise from the engine... i'm not sure if it's from the engine or the tranny... i only happens when the engine is in motion... if it's on park and i rev the engine no popping... but when i put it into drive and drive around i would hear this popping since i live on top of a big hill i put the car into neutral and roll it down the hill the i can still here the popping noise with the engine on of course... at first it only happened for a short time then it would go away but now it seems to be popping continuesly but randomly too..
i'm thinking it's time for a new engine within the this year...
syang is offline   Reply With Quote
Old 01-16-2006, 06:43 AM   #2 (permalink)
View Gary_602Z's Photo Gallery
Sounds like a CV joint to me !!
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 01-16-2006, 07:49 AM   #3 (permalink)
Pissed
View Camryamnesty's Photo Gallery
Jack up your car, pull a front wheel off, and check the boot on the cv axel, if its broken replace it, if not:
ask yourself
1. Am i sure this noise is coming from the engine?
2. When does it happen most?
3. Why doesnt it make the noise in park?
Camryamnesty is offline   Reply With Quote
Old 01-16-2006, 08:59 AM   #4 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
Maby bad oil pump or not enoph oil? B.c like you said it doesnt happen when you rev it. And also you live on a big hill so the oil might be going to one side of the oil pan. Might be valve nocking b.c of low oil pressure.
BlackCamSe is offline   Reply With Quote
Old 01-16-2006, 01:26 PM   #5 (permalink)
i think i may be low oil pressure because both my axles just got serviced or changed about 6 months ago so i'm pretty sure it's not the axle... btw how would i go about checking the oil pressure?? thx
Old 01-16-2006, 02:06 PM   #6 (permalink)
Moving Forward
View Cyorke's Photo Gallery
is the popping noiise constant or only whe you accelerate or decelerate. IF it is only when you do one or the other it could very posibly be motor mounts allowing the engine to move more than it should.
As for checking the oil pressure you have to remove the oil pressure sending unit and install a oil pressure guage in its place. then run the car at different speeds to see wht it is. You can probably buy one pretty cheap or mabe autozone rents one out. If you know someone that has one that is an option also.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
How do you warm up your car? kenratboy General Discussion 64 09-05-2007 11:20 PM
engine noise? image Camry & Solara Lounge 5 05-03-2005 01:53 PM
my Camry 03 makes loud noise from engine room! poraminna 5th & 6th Generation (2002-2006 & 2007-2011) 6 02-23-2005 09:19 PM
Engine noise after parked my 04 Corolla bluemm Archived Corolla threads 9 11-22-2004 09:15 PM
Engine Knocking/tapping noise in gen2 camry?? smt_007 1st & 2nd Generation (1983–1986 & 1987-1991) 6 11-11-2003 05:55 AM
