Oil in new cars - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-17-2006, 01:31 AM   #1 (permalink)
View fredster34's Photo Gallery
Gen5 Oil in new cars
i wondering if there's cheapo oil in cars on the lot. i'm waiting to reach my first 5000 miles until i change to some premium oil e.g. Mobil 1. jus curious as to wuts currently inside my engine.
fredster34 is offline   Reply With Quote
Old 01-17-2006, 01:44 AM   #2 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
I suppose it would have "Toyota" brand oil of whatever viscosity they recommend from factory (10w30 maybe for the Gen 5??)...
JetspeedCamry is offline   Reply With Quote
Old 01-17-2006, 04:38 AM   #3 (permalink)
The Other White Meat
terrastrife's Avatar
man your first oil AND oil filter change should be around 2500miles, then again another oil and filter change at 5000 miles...
i surely hope youve been giving your engine a beating to allow it to wear in properly. going like a granma will only result in a very very poor seal for the top 2 rings.
terrastrife is offline   Reply With Quote
Old 01-17-2006, 11:23 AM   #4 (permalink)
View keithy's Photo Gallery
I think, it is safer to change your oil at 3k miles(since you don't know what's in your engine now). Since it is new car, go synthetic all the way. Mobil 1 will be a good choice. It is also good to have a good oil filter.
keithy is offline   Reply With Quote
Old 01-17-2006, 05:05 PM   #5 (permalink)
TN User
View LinQ28's Photo Gallery
Changed my oil and filter at 3k for my 05 Camry. Drove the car for 6 months before I got 3k on it. I suggest you change it at 3k as well. The oil was dirty but didn't notice many metal flakes in it. I used a toyota filter from the dealer for the replacement. You may want to use a tool that will help you remove the filter, as it took my boyfriend and I almost an hour to remove mine using our hands (mostly his) because the tools we had didnt fit my filter.
LinQ28 is offline   Reply With Quote
Old 01-17-2006, 05:16 PM   #6 (permalink)
synthetic is only useful in ultra cold weather, if you have snow and ice etc i your area.
high performance cars and bikes, if not in snow and ice do not need synth, a good dino oil is fine.
oil and air filters should be more of a concern to you if you want to protect your engine.
Old 01-17-2006, 06:18 PM   #7 (permalink)
Gameroom cash: $101605
View kenny1773's Photo Gallery
I changed my oil and filter at 2k miles. I used a purolator pure one filter and regular mobil drive clean 5000 oil.
I changed it again at 5k miles and put in Mobil I synthetic. I stuck with purolator filters, but dropped to the premium plus level.
One a camry, I wouldn't put synthetic in too early. I would go on dino oil at least the 5000 miles.
No one NEEDS synthetic oil in a NA Camry, but it is nice knowing that by using it my engine will never sludge even if I miss my 5000k mile changes interval by 1000 miles I change oil about twice a year, so it costs me an extra $20, no biggy, sludge would cost an extra $5000 or so to deal with.
kenny1773 is offline   Reply With Quote
Old 01-17-2006, 06:25 PM   #8 (permalink)
mickeyd's Avatar
View mickeyd's Photo Gallery
I change the oil in my 03 matrix every 3k with toyota filter & toyota brand (mobile) 5w30 oil.
mickeyd is offline   Reply With Quote
Old 01-18-2006, 01:49 AM   #9 (permalink)
Gen5
really? the manual says otherwise, not to make hard accelerations until 1000 miles. i dont know, i just drive the darn thing
Old 01-18-2006, 06:12 AM   #10 (permalink)
if you dont give it early, the engine bore and rings will never 'mate' properly. for the first 10000m, change oil often, change oil filter even more often.
as soon as the engine is up to running temp, drive hard.
Old 01-18-2006, 07:57 AM   #11 (permalink)
View Camry005man's Photo Gallery
For Camry 05, oil change very 8000km (recommend) or 6 months whatever comes first. It's a good practice to follow the schedule.
Camry005man is offline   Reply With Quote
Old 01-18-2006, 08:07 AM   #12 (permalink)
View Gary_602Z's Photo Gallery
Man for the first change I would do it by 1000 miles! After that I would go recomended intervals or sooner.
Here is a link about breaking motors in that I think terrastrife had posted somewhere before.
http://www.mototuneusa.com/break_in_secrets.htm
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 01-18-2006, 08:22 AM   #13 (permalink)
View scootertrog's Photo Gallery
I changed my oil and filter at the 300 mile mark with regular dino oil. Then at 2,500 with Mobil 1. I will change it again at 5,000, and every 5,000 thereafter, using the Mobil 1. I always use a Toyota filter. Done several new cars this way, the engines in all of them went well over 200k.
scootertrog
scootertrog is offline   Reply With Quote
Old 01-18-2006, 10:24 AM   #14 (permalink)
F- the manual
Old 01-18-2006, 01:26 PM   #15 (permalink)
Nice reference to Mototune's site, Kenny. I agree completely with their position on the most wear occuring right at the beginning of the engines' life. Todays' engines are manufacted under much tighter tolerances than in the "good ol days", when "break-in" was harder to attain.
Now days, after the initial ring-seating has taken place, seal failure is going to be the most likely engine problem you will ever have - unless you got a GM, Ford or Chyrsler product, and I'll not bother to go there.
I really only use synthetic for 3 reasons: It cuts down on sludge buildup within the engine, reduced friction, which equals less rpm's @ a given h.p. output, and less patronage of Middle-East oil.
scootertrog
Men, Women and Oil Changes... BLUEMEANIE Off Topic 15 09-26-2007 09:42 AM
30,000miles on single oil change(how to help my car?) Part 2 Rob-D Camry & Solara Lounge 6 10-14-2006 12:26 AM
Oil Pressure sensor/switch lcarocha General Discussion 1 07-06-2005 05:22 PM
Need very hot temperature motor oil suggestions. Blek General Discussion 20 07-15-2004 09:59 PM
Mobil1 5w-30 Synthetic and my 2002 Corolla??? gadawg Archived Corolla threads 6 01-26-2004 04:39 AM
