Transmission Fluid Flush - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-17-2006, 04:08 PM   #1 (permalink)
View imranumd's Photo Gallery
Hi gusy,
I have 94 Camry. I got oil change at Tires Plus last week and they recommend to have "Transmission Fluid Flush". Is this a good idea to do it now when there is no problem with the transmission? Thanks,
K.
imranumd is offline   Reply With Quote
Old 01-17-2006, 04:25 PM   #2 (permalink)
View Gary_602Z's Photo Gallery
No! At that age I would just do a Filter and drain and fill. You will change out about 1/3 of the fluid that way. Then in about another 5-10k do the same thing. To many horror stories about tranny's going out after a flush. They recomend it because it is a money maker for the shops.
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 01-17-2006, 05:00 PM   #3 (permalink)
Let me out of my cage....
HATEnFATE's Avatar
Gameroom cash: $163450
View HATEnFATE's Photo Gallery
NEVER NEVER NEVER replace the trans filter on a toyota vehicle! thats just a waste of money.
Pull the drain pan and clean out the filter by spraying it with brake cleaner. Then replace the gasket and reinstall the pan and fill your trans back up.
toyota uses a metal filter that unless it's damaged should NEVER be replaced.
The reason shops recommend a flush isn't because of the money(well yeah it is) but also because they're philosophy is why risk taking off the pan and having a leak. If they don't remove it they aren't responsible for a leaking transmission.
Flushes don't hurt newer transmissions but could break some particles loose on an older one and cause the valve body to get clogged.
At your cars age I would recommend me first mentioned practice of removing the pand and cleaning your filter and getting new fluid. Changing transmission fluid is as vital as changing oil. It just lasts longer is all.
"Fools", said I, "You do not know, silence like a cancer grows.
Hear my words that I might teach you. Take my arms that I might reach you"
But my words, like silent raindrops fell, and echoed, in the wells of silence.....
Jason Johnston
Toyota/Scion of Des Moines
(800)342-7045
HATEnFATE is online now   Reply With Quote
Old 01-18-2006, 08:56 AM   #4 (permalink)
'93 LE Wagon, V6
View DFBonnett's Photo Gallery
Originally Posted by imranumd
Hi gusy,
K.
The trans flush is a very delicate procedure called a "wallet cashectomy". Forget it. Never flush. Do yourself a favor. Pick up a few spare trans drain plug gaskets from Toyota, pull the drain plug, drain, install plug and torque to 36 lbs/ft , replace same amount as drained.
Do this once a year and your trans should last the life of the car if you don't beat hell out of it.
DFBonnett is offline   Reply With Quote
Old 01-18-2006, 09:47 AM   #5 (permalink)
Pissed
View Camryamnesty's Photo Gallery
First, pull out your dipstick, and check the fluid if its red, its fine, if its kind of brown... go ahead and drop your pan, thats the only real way to tell.
Camryamnesty is offline   Reply With Quote
Transmission Fluid flush copper 1st Generation (1995-1999) 1 11-16-2005 08:16 PM
1996 Camry Automatic Transmission Fluid toyteam 3rd & 4th Generation (1992–1996 & 1997–2001) 3 08-15-2005 12:52 AM
transmission flush andyjl Camry & Solara Lounge 20 07-21-2005 11:13 AM
Draining & flushing the Automatic Transmission fluid while the car is running cato47 Camry & Solara Lounge 0 06-24-2005 06:55 AM
Transmission failure. Very sad. alchu Camry & Solara Lounge 1 06-14-2004 10:06 AM
