pinging? knocking? clutch? noise? maybe?
Hello everyone!
ok, you know when some times you take off from a very low rpm in a fairly old car (by mistake, mostly), say 500RPM, sometimes you get this chattering, sputtering, kinda like pinging noise? Well, I'm getting the exact same noise when I accelerate from a low speed cruise, or even a shift, sometimes.
Say I shift up to second gear, RPM drops to about 1500rpm; as I gas-in and ease off the clutch, I hear a very brief moment of that noise. Never had a car that does this before, it does it to 3rd and fourth gear too, probably 5th gear as well, but by that time the wind noise is too loud for me to hear it.
I always though the low RPM noise is from engine under too much load, so it pings. But for some reason, it seems to be associated with the clutch, because it usually happens at the very moment my foot leaves the clutch. ( when shifting )
My engine doesn't ping going up hill. Maybe the knock sensor detects it and regard the timing, don't know.
By the way, I bought this car a couple of months ago, and had the clutch replaced very soon after the purchase. The guy didn't seem to do a very good job changing the clutch though, the pedal kinda vibrates.
Could it be skipping? since it hasn't seat yet? I told him to resurface the flywheel, I hope he did. about 400miles city driving since the clutch job. All toyota parts, includes a re-man pressure plate
Does anyone know what is making that type of noise?
If it's carbon deposite build up causing engine knock, do you think premium gas would reduce the noise a bit?
