I spent all afternoon yesterday trying to wrench out my O2 sensor. I've got a V6 - its the one behind the engine, next to the firewall, so no good leverage. I made sure the engine was hot when I tried (not fun BTW). I even attached a rope to the ratchet and pulled on that.
I'm afraid it might be seized. Any advice on getting it out?
Spray it with some sort of a rust penetrant. even WD-40. get it soaked and let it sit for about 15 minutes.
"Fools", said I, "You do not know, silence like a cancer grows.
Hear my words that I might teach you. Take my arms that I might reach you"
But my words, like silent raindrops fell, and echoed, in the wells of silence.....
Jason Johnston
Toyota/Scion of Des Moines
(800)342-7045
You could always use a torch and heat up the pipe around the o2 sensor, take a wrench and breaker bar and gently twist it out. I watched the muffler shop do that with my stock exhaust when I had my cat-back installed, and they were able to reuse it as well. What i saw was that they heated the pipe till it was red hot and they unscrewed the sensor. but if you do not have access to a torch, WD-40 and a breaker bar will do just fine. You will just have to let the WD-40 sit for a bit so it can soak through.
The exhaust manifolds are subjected to the most heat in the system... therefore the expansion and contraction of them tends to form a TIGHT grip on O2 sensors... its often very difficult to get the sensors out without damaging them on an unheated piece.
THE BEST WAY is to heat the fitting with a torch. OR if the manifold is still on the car.. run the car un to operating temp for a few minutes, and then take it off with the manifold HOT. careful with your hands, wear gloves, and you will be all set.
