Radiator fan speed - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-19-2006, 12:52 PM   #1 (permalink)
View sameer2601's Photo Gallery
4th Generation Radiator fan speed
i have recently changed my radiator and noticed a difference in the fan speed. the old radiator was recently leaking from the top (Plastic top) and i swapped it to a metel one. however after the swap i noticed that there is a increase in both the fan speed. the temperature stays normal like before. is it normal or something to do with the new radiator or sensors.
97 camry le
128000 Miles
sameer2601 is offline   Reply With Quote
Old 01-19-2006, 05:10 PM   #2 (permalink)
Moving Forward
View Cyorke's Photo Gallery
replacing the radiator should not affect the speed of the fan motor. maybe the fan was dropped or damaged in someway and that is causing the difference in fan speed now.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 01-25-2006, 03:59 PM   #3 (permalink)
Dude Wheres My Car?
nukem678's Avatar
View nukem678's Photo Gallery
If your cam is like mine your fans have two speeds. Youl notice this if you turn your a/c on and wait for the car to heat up. When you reach operating temp the fans will start spinning faster and Then after the cars cooled down a bit, they will go to the lower speed.
I lost my Camry in a parking lot once, Now it will never happen again
nukem678 is offline   Reply With Quote
interesting article about double clutching boroEF Hardcore Tech and Competition 40 07-23-2007 01:12 AM
Speed freak MR2Jedi Off Topic 13 06-09-2005 12:06 AM
Tire suggestions? Vaipunk Archived Corolla threads 11 03-11-2005 06:48 AM
Advice Needed (6/5 speed swamp) urbandork Archived Corolla threads 9 06-09-2004 11:56 AM
5 speed auto or 5 speed stick Talisman Camry & Solara Lounge 22 12-17-2003 03:17 PM
