Originally Posted by Camon19z
sso if they all have that feture how exactly wud i go about wiring it?
In all 3 models that I mentioned in my previous post, 2 DARK GREEN with WHITE trace provide this function. If yours is one of those models(or similar)...
I'll quote from one of the installation manuals:-
"ENTRY ILLUMINATION."
"The dark green w/white trace wires provide the entry lighting, and flash the dome light while the alarm is sounding.
These are the N.O.(Normally Open) and COMMON contacts of an onboard 10A(max) relay.
Connect one of the DARK GREEN w/WHITE trace wires to the switched output of one of the doors pin switches.
Connect the other wire to either chassis ground(GM and most imports)or a fused +12v battery source (most FORDs), depending upon the polarity of the dome light circuit in the vehicle.
NOTE: When wiring this feature in vehicles with factory equipped delay lighting circuits, it is best to connect to the output of the timer which feeds the dome light , rather than at the door switch. This will ensure that the dome light pulses when the alarm is triggered".
In my cars I hooked one wire to the door switch, the other wire to ground.
But why not go back to the installer?, you paid him to hook it up, if your alarm unit can provide this feature make him hook it up.
HTH
JerryR
