Idle on the Camry V6 motor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-27-2001, 01:24 PM   #1 (permalink)
View erfan's Photo Gallery
Hi,
I have a 1995 Lexus ES300 and it has 94K miles and i had the uppermotor mount replaced and plugs and Valve stem seals done. My car has a real low frequency vibration at idle in drive. It is a very tiny vibration when i am at a light. Is this normal for the V6 or is it supposed to be perfectly still at idle? Please camry owners tell me am i imagining things?
thank you
Erfan
erfan is offline   Reply With Quote
Old 11-27-2001, 01:38 PM   #2 (permalink)
View benyu's Photo Gallery
Yes there is a very low frequency of vibration when idling in drive.
Try to shift to neutral and see if you can still feel the vibration.
- Know your limit, and perform to the limit
benyu is offline   Reply With Quote
Old 11-27-2001, 03:35 PM   #3 (permalink)
Hi,
Thank you for your response, i thought i was going nuts! I was told by my toyota dealership that it is normal. When i put it in neutral the vibration is gone completely.
Old 11-27-2001, 04:49 PM   #4 (permalink)
Welcome to the forum, by the way.
Old 11-27-2001, 04:57 PM   #5 (permalink)
thanks, so, please describe the vibration that you feel. Does it kind of radiate throught the steering wheel? What do you think of the 1995 Lexus ES300?
Thanks
Erfan
Old 11-27-2001, 05:43 PM   #6 (permalink)
TN Legal Team
View SpectraBlueCam's Photo Gallery
That idle vibration is perfectly normal. Don't worry about it. Just remember that the Lexus line is famous for its smoothness and the cabin's isolation from the engine. On other cars, that vibration is much worse.
As for the 95 ES, it's a solid vehicle with a great reputation for reliability. You made a good choice.
I'm SUPER, thanks for asking;
All things considered I couldn't be better I must say.
I'm feeling SUPER, no, nothing bugs me;
Everything is SUPER when you're...
SUPERCHARGED!
SpectraBlueCam is offline   Reply With Quote
Old 11-27-2001, 06:04 PM   #7 (permalink)
Turbo-Yota power
Jzs147-RR's Avatar
View Jzs147-RR's Photo Gallery
Well i have that same problem on my 1997 and its just with age the car seem to vibrate more because parts get loose .BTW i love the ES300 it is a good car built on a perfect frame(same as Camry :wink: )
5sfe powered turd ...
Jzs147-RR is offline   Reply With Quote
Old 11-27-2001, 06:10 PM   #8 (permalink)
Is it common for the Power steering rack and the pump to leak on it? Because it has a small leak from those components, I also had to have the valve cover gaskets replaced and the valve stem seals done as well.
Old 11-27-2001, 06:17 PM   #9 (permalink)
Turbo-Yota power
Jzs147-RR's Avatar
Ya its normal to have some leaks like that on a 1995 ,you have alot of milage so its going to have minor repairs to do on it.On my 1997 Camry i have already had to change my knock sensors and that was expensive but it was needed.If you wnat they sell fluid that can block leaks , try to find some otherwise just see if you cant get the parts urself and do the repairs.
Old 11-27-2001, 07:27 PM   #10 (permalink)
Toyota Lexus Scion Guru
View Flipside909 [SC³]'s Photo Gallery
If your rack is leaking, you're gonna have to replace it. I know a few people who had to do this including myself. Started with a small leak...and the small leak turned into huge puddles on both sides of the rack. The only fix is a replacement. Here in the states...a rebuilt rack costs around $600 and add labor to that. Imagine what a brand new rack costs...you can forget that idea! I spent $800 total on my 95 Avalon XLS to get the stupid rack replaced. Now it's good as new. 98900 miles and still running strong.
ClubLexus Editor/Events Coordinator
GRS191
Flipside909 [SC³] is offline   Reply With Quote
Old 11-28-2001, 10:02 AM   #11 (permalink)
Thanks guys, you are nice people
Erfan
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 10:55 PM
could you get away with it bondobondo General Discussion 46 07-06-2002 12:00 PM
96 Camry LE V6 vs 98 Camry XLE V6 2001CamryLE 3rd & 4th Generation (1992–1996 & 1997–2001) 7 05-13-2002 07:53 PM
TCI ANNOUNCES PRICES OF ALL-NEW 2002 CAMRY - F bondobondo 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-14-2001 12:48 PM
