Help!!!!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-21-2006, 09:56 PM   #1 (permalink)
southern racer
View JLcamrydave's Photo Gallery
4th Generation Help!!!!!!
This is a vary big problem i have well i have a gen 4 camry 4cyl the problem is my head lights and my tail lights do not work but here is the catch none of the fuses are blown under the hood or where the fuse box is in the car my break lights work my blenkers work but nothing else my headlights guages and tail lights do not work could it be somethin to do with my computer plezzz if anyone knows give me some advice bc i a cant drive at night
JLcamrydave is offline   Reply With Quote
Old 01-21-2006, 10:49 PM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
it wouldn't be the ecu....the ecu doesn't affect the lights
have you checked to see if your relays are okay? if you flip your lights to highbeam, even if they won't work, the relay should still click
but more importantly, check to see if you have any loose wiring at your light switch on your steering column
HaHa
Old 01-30-2006, 07:21 PM   #3 (permalink)
View marc780's Photo Gallery
None of em work? What controls em all, the STALK SWITCH thats what . You probably need a new stalk switch(the thing sticking out turn signal lever ), you can find out before laying out all that money; remove the switch and jump the contacts with wire or something, if you get lights then it most likely is the stalk switch - also could be your ignition switch? Not likely if it starts though.
Maybe also a bad ground but again, if it runs ok, this is probably not it.
