PWR window doesn't work - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-22-2006, 04:37 PM   #1 (permalink)
View familyman's Photo Gallery
3rd Generation PWR window doesn't work
Hi guys,
I have a problem on the pwr window. It used to be OK with 3 windows expect for the rear left one. But after I had someone fixed it for me, the two windows on the right handside don't work anymore. I checked the switches and am sure that those are good. I also tried to connect the corresponding pins directly with wires instead of switches, but nothing happened. So I wonder if you guys have any idea on where I should check. The windows just won't go up and down no matter which switch I use.
Thanks!
familyman is offline   Reply With Quote
Old 01-22-2006, 07:18 PM   #2 (permalink)
V6LE_CAMRY's Avatar
View V6LE_CAMRY's Photo Gallery
maybe the motors went out or whoever installed it did some thing wrong with the wiring. Or it could be the whole swhich box, but you said that you gave power to the directly, so that would bring you back with two more bad motors. IMO
V6LE_CAMRY is offline   Reply With Quote
Old 01-22-2006, 09:49 PM   #3 (permalink)
08 XR
iTrader Score: 6 reviews
View MrJones's Photo Gallery
me too
thats happened to me too but i dont want to bad mouth the person who helped you. turns out the guy that fixed my window regulator didnt really attach all the wires back and tried to get some more money from me. so yeh, maybe he didnt attach the wires back, if you're not afraid to open it up, do so and find out.
Originally Posted by ECale3 View Post
It's not about the destination, it's about the drive.
MrJones is offline   Reply With Quote
Brake lights won't work when headlights are on... Psykosoma Yaris, Vitz and Echo Forum 11 01-19-2008 03:38 PM
Window Troubles Your Uncle Moe Camry & Solara Lounge 7 08-25-2005 01:44 AM
Camry RH Window regulator & motor needed total1 Camry & Solara Lounge 9 05-24-2005 06:04 PM
brake lights, pwr window, '89, blues gipper89 1st & 2nd Generation (1983–1986 & 1987-1991) 3 12-04-2004 11:52 PM
Rear window problems (electrical) 96CamryDX Camry & Solara Lounge 0 12-01-2002 04:08 PM
