Water Leaks - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-22-2006, 10:07 PM   #1 (permalink)
View Edna's Photo Gallery
Unhappy Water Leaks
Help, I'm drowning. I have a 97 Camery XLE. The floor on the passenger side is soaked. It is not wet on the upper part of the floor just on the bottom. It only happens when it rains and the fluid does not have a smell or any color to it so it appears to be rainwater. I thought it may be a bad seal around the windshield however I've taken a hose and sprayed all around the windshield and no water has gotten into the car. I've also checked to see if there is a drain hole that may be plugged or if there is a plug on the underside of the car that may be missing.
Has anyone had this problem or can anyone offer some suggestions.
Edna is offline   Reply With Quote
Old 01-26-2006, 05:10 AM   #2 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
Canada
Edna, try posting this question in the Camry forum instead of the "introduce yourself" forum. You'll get a lot more people seeing your question.
Good luck!
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 01-26-2006, 11:05 PM   #3 (permalink)
View marc780's Photo Gallery
The water may be coming in where you cant easily see it from inside. Like at the bottom part of the windshield and then leaking down behind the dashboard and then the inside firewall. (Or it could be coming in the door seal but not likely.) Id have the windhsield reinstalled with a new gasket and sealer, trying to patch the seals has never worked for me.
Since you say it only happens in the rain its not likely that the heater core could be leaking, is it?.
The Free Mod Series: Part VII Cheap Water Injection Toysrme Camry & Solara Lounge 17 05-26-2010 02:13 PM
water leaking from radiator. help games615 Camry & Solara Lounge 3 12-19-2005 07:17 PM
Water Injection system installed + more Tony the Tiger Camry & Solara Lounge 63 11-03-2005 04:49 PM
moonroof leaks to trunk Jerryb Camry & Solara Lounge 5 01-02-2005 05:07 PM
