plug wire options???? is there?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-23-2006, 02:31 AM   #1 (permalink)
View DoomCrewInc's Photo Gallery
2nd Generation plug wire options???? is there??
ok i have a 90 dx I4 3s-fe. the only aftermarket plug wires i can find are the Nology ones.(are they worth that much money?) Are there any other brands out there for the gen 2 4cyl? i tried searching for NGK ones but only found em for the 3rd gen and up!
also how big of a diff will a set of denso iridiums work in this motor? any other plug suggestions? i have read some posts about copper ones, but cannot find any, i am currently running denso/ngks. thanks again! other perf oriented mods are: custom intake(homade short ram w/ heat shield, custom cat back exhaust(2 1/4" piping back to universal muffler).
DoomCrewInc is offline   Reply With Quote
Old 01-23-2006, 03:50 AM   #2 (permalink)
Sebastian Loebs evil twin
BakaWill's Avatar
View BakaWill's Photo Gallery
Well.........
performance wise plug wires don’t do n e thing. If you’ve got a weak spark its usually that f****** ignition coil. <on the bottom of the distributor and what’s more fun is that you HAVE to take the distributor off to change it.
1990 camry dx 3s-fe
BakaWill is offline   Reply With Quote
Old 01-23-2006, 08:29 AM   #3 (permalink)
View stockrex's Photo Gallery
check the connectors at the end, sometimes they bend and become loose, squeeze them together with a needle nose plier for a tighter fit.
someone pls explain to me How Plug wires DEGRADE over time?
else check the moving parts of the spark mechanism if any, else the coil.
good luck
stockrex is offline   Reply With Quote
Old 01-23-2006, 10:52 PM   #4 (permalink)
im not having any spark probs, its just i dont like the quality of the autozone ones. hmm, maybe ill check into doing an MSD setup. ill do some searching and see what i come up with.
what about the plugs?
Old 01-24-2006, 12:07 AM   #5 (permalink)
The Other White Meat
terrastrife's Avatar
wear.
terrastrife is offline   Reply With Quote
Old 01-24-2006, 01:09 AM   #6 (permalink)
i found some of 88le's posts and pics of the msd on his car. i think imma go that route.
Old 01-24-2006, 01:10 AM   #7 (permalink)
BakaWill's Avatar
Well…. Plug wires degrade because of several factors mainly the heat from the engine, oxygen, and even the electrical current they carry.
1990 camry dx 3s-fe
Old 01-24-2006, 09:48 AM   #8 (permalink)
megamac83's Avatar
View megamac83's Photo Gallery
Yo check out this site NGK.COM, these spark plugs are dirt cheap and they have a good name, I am now running Bosch plugs with NGK wire, and I have no problems should have used NGK plugs but I had already bought the Bosch plugs, but anyways good shopping like i said click here to go the site and look for the search by car on the left hand side GOOD STUFF if you know what i mean for pretty much any car, wires are about half the price as compared to BS plugs at the auto parts store
megamac83 is offline   Reply With Quote
Old 01-26-2006, 01:57 PM   #9 (permalink)
thanks for the link megamac, that is exactly what i was looking for, NGK wire set for the 3s-fe. not a bad price either. the iriduim plugs i can get locally for the same price though.! thanks again!
MSD Ignition luisitol Camry & Solara Lounge 23 03-15-2009 02:13 PM
Wire Layout Plug in Overhead console please~! ohnoyuji Camry & Solara Lounge 5 10-08-2005 12:34 AM
Can a Bad Plug Wire Cause Clogged Cat? mnwolftrack Camry & Solara Lounge 3 07-04-2005 08:01 PM
extra battery 97avalonxls Audio, Video, and Security - Tech 9 09-20-2004 12:09 PM
Spark plug wire boot ']['R][) camry Camry & Solara Lounge 10 04-18-2004 12:59 AM
