Auto Transmission
Hi -
I'm new to this forum. I did a search and wasn't able to find the info I was looking for.
My wife owns a 1999 Solara SLEV6 - automatic. I'm posting on the Camry forum because I think the transmission is the same. The car has 63,000 miles on it. She is the original owner. The car has never been abused or neglected.
At 60,000 miles, I drained the ATF & replaced w/Dexron III. I checked the owners manual and asked at the auto parts store & they both said the capacity was 5 quarts. I put in 4+ quarts & checked the level. It seemed high but I thought it might circulate down to the correct level.
After driving 2700 miles I could smell hot ATF. I checked the fluid, it was dark & smelled burned. I called the dealer & they said the refill capacity was 3.7 quarts. So, we drove the car 2700 miles overfilled by 1+ quarts. I drained & refilled the ATF to the appropriate level.
The transmission seems to slip now when cold.
How much damage has been done? Is the slippage likely to get worse? Has this happened to anyone else? Do I have any case against Toyota since I filled to their recommendations?
Thanks!
