rear sway... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-23-2006, 06:31 PM   #1 (permalink)
fungke's Avatar
View fungke's Photo Gallery
Gen5 rear sway...
i know that this topic has been discussed many times. the rear creaking noise experienced after installing a rear sway bar on the gen5. i got mine installed about september or so. bought the sway from the dealer and got them to install it as i did not trust my self.
since then, it has been making noises when i go over bumps and such. the forum told me get the bushings relubricated and that was done. it worked for a couple of weeks and the noise came back. i hear it more on colder days...i bring it back...theyexperience it and relubricate it..now i hear it again, this time...more faint and more intermitant than before.
my question is...can the sound be recreated without driving the vehicle through bumps?
is there a particular grease i should as them to use?
03 Camry SE
fungke is offline   Reply With Quote
Old 01-23-2006, 06:53 PM   #2 (permalink)
amerikim's Avatar
View amerikim's Photo Gallery
Lithium Grease.
old faithful
amerikim is offline   Reply With Quote
Old 01-23-2006, 08:22 PM   #3 (permalink)
bitch please
DarkMastyr's Avatar
View DarkMastyr's Photo Gallery
Teflon tape
1994 Camry 2.2L LE Auto
DarkMastyr is offline   Reply With Quote
Old 01-23-2006, 09:15 PM   #4 (permalink)
The Cool Guy
Super Kaioken's Avatar
View Super Kaioken's Photo Gallery
yeah i would say grease it up. or tighten the bolts maybe? mine doesn't make noise
-Custom 2.5in Cat-back Exhaust + Borla Muffler + Weapon R Dragon Intake + TRD Rear Sway Bar + TRD Springs + TRD Front Strut Brace
Super Kaioken is offline   Reply With Quote
Old 01-24-2006, 06:56 AM   #5 (permalink)
fungke's Avatar
do i need to take it apart to apply this stuff?
it goes in between the bushings and the bar?
03 Camry SE
Old 01-24-2006, 01:17 PM   #6 (permalink)
Lives For The Curves
View nort0188's Photo Gallery
The bushings are flush around the bar, so to get anything in there, yes, you do need to take them off. Should be a very simple job, just unbolt the brackets, pull the bushings off, lube, and re-assemble. You don't need to bother with end-links or trying to slide the bar in and out.
If torque actually won races, wouldn't we all be driving diesels?
nort0188 is offline   Reply With Quote
Old 01-24-2006, 01:37 PM   #7 (permalink)
Camry Gen 5.5 User
arcimpulse's Avatar
View arcimpulse's Photo Gallery
how much did it cost the dealer to install it for you?
arcimpulse is offline   Reply With Quote
Old 01-24-2006, 08:31 PM   #8 (permalink)
fungke's Avatar
$100...
took them 45 minutes
03 Camry SE
Old 01-24-2006, 08:33 PM   #9 (permalink)
The Cool Guy
FUNGKE! uhh.....are the bolts on tight? maybe put it on the stiffest setting. i dunno. my car handles better now though.
Old 01-24-2006, 11:16 PM   #10 (permalink)
fungke's Avatar
i am assuming that they are tight..
bringing it to the dealer for other work tomorro..new radio and check on intake manifold...
will ask them about the sway bar as well....my sway is on the stiffest setting...
did not notice much difference until i took a winter car control school...although body roll is still present...it has decreased and as such..i did feel that the car was more responsive to cornering. i guess i will see how it goes tomorro.
03 Camry SE
Old 01-25-2006, 12:43 AM   #11 (permalink)
View mkII's Photo Gallery
Lube them. You should lube them periodically. Moving parts can't stay lubed forever. This next time I do it would be my third. I have the bar set at the most aggressive setting.
i miss my mkii.
Gen 5 - 2002 Phantom Gray Pearl Camry V6 LE:
-TRD Rear Sway Bar
-SE Model Strut Tower Bar
-Borla Exhaust
-Injen Intake
-Sportivo Grille
-TRD Lowering Springs (sitting in my room waiting to be installed)
mkII is offline   Reply With Quote
TRD Rear Sway Bar Damage Super Kaioken Camry & Solara Lounge 7 06-20-2008 12:20 PM
Sway Bar for JDM Gen5 sqcamry2003 5th & 6th Generation (2002-2006 & 2007-2011) 3 10-05-2005 12:25 PM
rear sway bar question Night Speed Camry & Solara Lounge 2 08-15-2005 11:04 PM
Photos of my New MK1 Suspension install- GAB Sway Bars - ST Springs - illuminas justjoe MR2 Forum 0 06-04-2005 02:56 PM
