I don't think I remember the lower half of the that trim being held by any clips at all. I think the only clip that's on that trim piece is the one that lets you take off the lap belt out of the slot on the bottom. The only thing that's really holding that trim piece in place are the edges of it. Try removing it by starting at the bottom corners by the lap belt and work your way up, then you can pull it down and off of the upper trim.
Btw, I'm assuming you have removed both the door sills right? Or else you won't be able to take that trim off.
